So I bought a 2012 pro rmk 800. Has slp stage 4 kit on it. Every since I had it the sled would bog when WOT from a dead stop or would bog when WOT in general. Changed fuel filter and it did not work. I Was riding in the UP this past weekend and got the sled stuck. When I tried to start it again the pull cord would not move. Tried turning the clutch by hand and clutch was getting stuck after a couple turns each way. Finally got clutch to spin freely and when I started the sled it was running horribly. Almost like it was on one cylinder. Took out spark plugs because I thought it was flooded and the plug on the mag side looked like it was hit by piston. The gapping was way off. Rode it to nearest road to pick up sled and sled kept bogging at all speeds and rpm. The check engine light did not come on at all. Not sure if its not getting fuel or what it is. Need help ASAP to get this figured out. Everything I read so far there is countless things that could be wrong. Thanks.
