Upgrade to Premium
Arctic Cat: Proclimb M 2012 and beyond
View Poll Results: 2016 Front End or Clutching/Jackshaft/Gears
2016 Front End 27 62.79%
2016 Clutching/Jackshaft/Gears 16 37.21%
Voters: 43. You may not vote on this poll
Reply
  #1
Old 09-13-2015, 09:06 PM
j.janke j.janke is online now
Currently: Dreaming of Sledding
j.janke has a reputation beyond reputej.janke has a reputation beyond reputej.janke has a reputation beyond reputej.janke has a reputation beyond reputej.janke has a reputation beyond reputej.janke has a reputation beyond reputej.janke has a reputation beyond reputej.janke has a reputation beyond reputej.janke has a reputation beyond reputej.janke has a reputation beyond reputej.janke has a reputation beyond repute
Default 2016 Front End or 2016 Clutching/Jackshaft/gears
Been meaning to also ask this for a while now. Which upgrade do you think is most worth while making to a 2014 Proclimb 800; the 2016 front end, or the 2016 clutching/jackshaft/gears? There are lots of things on the list for this year but i have to pick most likely only one of them unless i win the lottery or rob a bank JK LOL. Please explain why as well.
Thanks again for your expertise!
__________________
Rate this post: Yes | No
The Following User Says Thank You to j.janke For This Useful Post:
dgibbons (10-19-2016)
  #2
Old 09-13-2015, 09:29 PM
CO 2.0's Avatar
CO 2.0 CO 2.0 is online now
Currently: Needs to snow
CO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond reputeCO 2.0 has a reputation beyond repute
Default
[Well Id have to say the jackshaft gears and clutching. Even though fun factor, the 16 front end is much better. The 14 jackshaft is a weak link. Im sure there are many that havent had an issue, but I snapped mine at 1000 miles. Upgrading to the 15 shaft was cheap and easy. About $100. 16 jackshaft is even better but havent heard of anyone snapping a 15 shaft yet. The chain on the 14 is weak and the bottom aluminum gear wears bad and quick. Failure potential is there. I broke a silent chain link at 500 miles. Luckily caught it with maintenance before it failed completely. Team has a nice bw hyvo chain and team steel gear setup for $200. Try 20/49. Although 19/50 does work and clutch temps stay lower. Last the stock primary spring is junk. Too high engagement and sacks out quick causing loss of rpm. Go with a speederx h5 alloy spring. Much better metal used and higher tensile strength over your standard chrome silicon spring. I used 120/310 in my 14. Gonna try a 114/285 in my 16 cause the clutches are different. Also buy some metal thunder products glide washers and put one under the primary spring in the cover. I tried one on both ends but one is enough to eliminate spring bind and not raise clutch engagement too much. $65 total for clutching. Stock weights work well enough IMO. Total of $365 or so
__________________
'18 Mountain Cat 153, '16 Axys 3" PC 153 Silber (Sold), '19 Alpha
http://www.weknowsnow.com
The Following 7 Users Say Thank You to CO 2.0 For This Useful Post:
Bills R.E. Repair (10-21-2016), catzr (10-20-2016), dgibbons (09-14-2015), fasta76 (09-14-2015), j.janke (09-13-2015), minet (10-04-2015), Mntryder (10-04-2015)
  #3
Old 09-13-2015, 10:00 PM
Default
Quote:
Originally Posted by CO 2.0 View Post
Well Id have to say the jackshaft gears and clutching. Even though fun factor, the 16 front end is much better. The 14 jackshaft is a weak link. Im sure there are many that havent had an issue, but I snapped mine at 1000 miles. Upgrading to the 15 shaft was cheap and easy. About $100. 16 jackshaft is even better but havent heard of anyone snapping a 15 shaft yet. The chain on the 14 is weak and the bottom aluminum gear wears bad and quick. Failure potential is there. I broke a silent chain link at 500 miles. Luckily caught it with maintenance before it failed completely. Team has a nice bw hyvo chain and team steel gear setup for $200. Try 20/49. Although 19/50 does work and clutch temps stay lower. Last the stock primary spring is junk. Too high engagement and sacks out quick causing loss of rpm. Go with a speederx h5 alloy spring. Much better metal used and higher tensile strength over your standard chrome silicon spring. I used 120/310 in my 14. Gonna try a 122/285 in my 16 cause the clutches are different. Also buy some metal thunder products glide washers and put one under the primary spring in the cover. I tried one on both ends but one is enough to eliminate spring bind and not raise clutch engagement too much. $65 total for clutching. Stock weights work well enough IMO. Total of $365 or so
Thanks C.0! The only thing that worries me a bit is going to a 20/49 because of the belt blowing issues with the stock clutching. Everything else seems fairly well explained and makes sense. So from what it sounds like, would you say it would be worth saving the money and just purchasing a 2015 jackshaft and the team hyvo chain and gears, Along with the clutching upgrades that you listed. So for me probably around 1000 CAD. Is that what you were thinking?
__________________
  #4
Old 09-13-2015, 10:11 PM
CO 2.0's Avatar
Default
Yeah. Havent looked up pricing on the 16 jackshaft. Not even sure its up yet on the parts fiche. Aftermarket shaft just seems overkill unless you are putting out a ton of power with turbo or super charger.
__________________
  #5
Old 09-13-2015, 10:15 PM
Default
Would I only need the jackshaft or also the assembly? At this link would I need part 21 or 22?
http://www.arcticcatparts.ca/OEMpart...%7c%7e0748-333
And which spring would you say i should go with?
__________________
  #6
Old 09-13-2015, 10:34 PM
CO 2.0's Avatar
Default
You need shaft, and all items behind top gear in chaincase side. Id also put a snap ring from 15-16 on the bottom gear. The one on there now is a pain in the azz getting off without the proper tool. Id go with 120/310 spring
__________________
  #7
Old 09-13-2015, 10:42 PM
Default
Ok great, I didnt know that team was bought by vennom so in order to get the team hyvo chain and gears i will have to contact them. Still curious to see wat others have to say but you definitely convinced me for the most part.
__________________
  #8
Old 09-13-2015, 10:56 PM
CO 2.0's Avatar
Default
Call michelle at oregon trail sports on Tuesday. She will set you up and get you the best deal
__________________
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #9
Old 09-13-2015, 11:05 PM
Default
I will call he anyways but I may be better off dealing with a Canadian dealer if possible. Thanks for the tips though i appreciate it! Looking forward to getting this stuff started once i get my sled back from the dealer. Ive had some issues over a large part of last season with it having a low end bog that ruins days. I can get it cleared out but as soon as RPMs lower again it begins to completely load up again and go to what sounds like its on one cylinder. Dealer is having problems pin pointing the issue. Nothing showing on the computer.
__________________
  #10
Old 09-13-2015, 11:35 PM
fast8seccamaro fast8seccamaro is offline
Currently: waiting on more snow!
fast8seccamaro has a reputation beyond reputefast8seccamaro has a reputation beyond reputefast8seccamaro has a reputation beyond reputefast8seccamaro has a reputation beyond reputefast8seccamaro has a reputation beyond reputefast8seccamaro has a reputation beyond reputefast8seccamaro has a reputation beyond reputefast8seccamaro has a reputation beyond reputefast8seccamaro has a reputation beyond reputefast8seccamaro has a reputation beyond reputefast8seccamaro has a reputation beyond repute
  #11
Old 09-13-2015, 11:57 PM
Click Here to Register
  #12
Old 09-14-2015, 10:11 AM
CO 2.0's Avatar
  #13
Old 09-14-2015, 10:26 AM
  #14
Old 09-14-2015, 10:39 AM
CO 2.0's Avatar
  #15
Old 09-14-2015, 10:56 AM
  #16
Old 09-14-2015, 12:41 PM
leadfoot33 leadfoot33 is offline
Currently: modding proclimb
leadfoot33 has a reputation beyond reputeleadfoot33 has a reputation beyond reputeleadfoot33 has a reputation beyond reputeleadfoot33 has a reputation beyond reputeleadfoot33 has a reputation beyond reputeleadfoot33 has a reputation beyond reputeleadfoot33 has a reputation beyond reputeleadfoot33 has a reputation beyond reputeleadfoot33 has a reputation beyond reputeleadfoot33 has a reputation beyond reputeleadfoot33 has a reputation beyond repute
  #17
Old 09-14-2015, 01:05 PM
  #18
Old 09-14-2015, 01:23 PM
madmax's Avatar
madmax madmax is offline
Currently: Not set.
madmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond repute
  #19
Old 09-14-2015, 03:48 PM
CO 2.0's Avatar
  #20
Old 10-06-2015, 02:34 PM
ailll1 ailll1 is offline
Currently: Not set.
Basic Member
ailll1 has a reputation beyond reputeailll1 has a reputation beyond reputeailll1 has a reputation beyond reputeailll1 has a reputation beyond reputeailll1 has a reputation beyond reputeailll1 has a reputation beyond reputeailll1 has a reputation beyond reputeailll1 has a reputation beyond reputeailll1 has a reputation beyond reputeailll1 has a reputation beyond reputeailll1 has a reputation beyond repute
  #21
Old 10-07-2015, 07:47 PM
CO 2.0's Avatar
  #22
Old 10-07-2015, 07:49 PM
ezra ezra is offline
Currently: close to the edge
Basic Member
ezra has a reputation beyond reputeezra has a reputation beyond reputeezra has a reputation beyond reputeezra has a reputation beyond reputeezra has a reputation beyond reputeezra has a reputation beyond reputeezra has a reputation beyond reputeezra has a reputation beyond reputeezra has a reputation beyond reputeezra has a reputation beyond reputeezra has a reputation beyond repute
  #23
Old 10-07-2015, 07:51 PM
Basic Member
  #24
Old 10-19-2016, 08:13 PM
armey37's Avatar
armey37 armey37 is offline
Currently: cat
armey37 has a reputation beyond reputearmey37 has a reputation beyond reputearmey37 has a reputation beyond reputearmey37 has a reputation beyond reputearmey37 has a reputation beyond reputearmey37 has a reputation beyond reputearmey37 has a reputation beyond reputearmey37 has a reputation beyond reputearmey37 has a reputation beyond reputearmey37 has a reputation beyond reputearmey37 has a reputation beyond repute
Garage
  #25
Old 10-27-2016, 08:48 PM
Allseasons Allseasons is offline
Currently: Counting the days
Allseasons has a reputation beyond reputeAllseasons has a reputation beyond reputeAllseasons has a reputation beyond reputeAllseasons has a reputation beyond reputeAllseasons has a reputation beyond reputeAllseasons has a reputation beyond reputeAllseasons has a reputation beyond reputeAllseasons has a reputation beyond reputeAllseasons has a reputation beyond reputeAllseasons has a reputation beyond reputeAllseasons has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2016 front end? Thread Starter — mmsports Forum — Arctic Cat: Proclimb M Replies — 62 Last Post — 01-09-2017 06:09 PM
Thread — 2016 Front End or New CamoX 3.2 Thread Starter — Icedog Forum — Arctic Cat: Proclimb M Replies — 35 Last Post — 10-25-2015 10:33 AM
Thread — 2016 SR Viper front end on a 2015? Thread Starter — Sharp Forum — Yamaha: 4-Stroke Replies — 42 Last Post — 09-18-2015 04:36 AM
Thread — BDX 36" 2016 front end update Thread Starter — bradburck Forum — Arctic Cat: Proclimb M Replies — 11 Last Post — 08-12-2015 02:31 PM
Thread — 2016 front end? Thread Starter — Mikeymsp Forum — Arctic Cat: 1100 ProClimb Replies — 6 Last Post — 04-06-2015 07:51 AM
no new posts
