A
I would like to start a thread about tuning and map creation tips for sleds with the power commander 5. Answer the following questions.
1. Did you hold rpm constant and vary throttle position while watching air fuel numbers?
2. Did you hold throttle position constant while varying rpm to get target afr?
3. Did you find it necessary to vary the map significantly from block to block for example: fuel numbers going 10 50 10 90 instead of 10 15 20 15 10?
4. If you had an M, were you able to check piston wash without removing the exhaust manifold? I don't think I can fit my head down there.
5. Did your air fuel numbers vary with altitude using the PCV box? I was told by speedwerks that with the PCV the fuel numbers do not need to change for different altitudes, i have a hard time believing that.
6. Mods list
Pipe:
Intake:
Reeds:
make/model:
Heads:
timing keys:
type Air Fuel gauge system:
7. Any tips and tricks to minimizing the amount of time spent tuning?
8. Is there a PDA available so you didn't have to take your laptop with u riding that you used?
9. comments:
For example on the SLP map, in the fuel number blocks from 7250 to 8000 rpm and from 15 to 30 percent throttle, slp maxed the numbers at 124 while the surrounding fuel numbers are between 35 and 10. Is this because at max rpm and low throttle there was a huge lean spot letting off the gas? Speedwerks map did not do this. Both maps I have are included.
6. Mods list
Pipe:
Intake:
Reeds:
make/model:
Heads:
timing keys:
9. comments:
