08 M1000 rear bogey wheel removal
H
HiWaYman92
818
125
Pinedale, Wyoming
You will need to do a 'two wheel kit'. BDX makes one, along with other brands. Its basically a new shaft, and you flip your tensioners to the inside and remove the middle wheels and put your outer bogies on the inside. They are about 30 bucks from your dealer or www.bd-extreme.com
H
HiWaYman92
818
125
Pinedale, Wyoming
I guess you probably could, I could not because my king cat only had three wheels, and my M only had three. If you had a sled with four I suppose you probably could use the inner black ones.
R
rigrat
Apr 19, 2008
266
36
Alberta
Just had mine done 2 days ago, bought 2 wheel axle from AC and used just the black inside wheels.
mrquick68
1,983
372
83
Kirkland, WA
i personally run a MMP two wheel kit (a little bling) and that's it in the entire skid. No boggies anywhere... just a set of scratchers for when the snow is low.
