Be careful, my dad's 2000 MM700's oil light would turn on but go off when he gave it gas. Now the sled is sitting on the trailer rotten because we can't figure out whats wrong with his sled. It started over revving then died out. Everything locked up on the sled except the track, turned the clutch and everything unlocked. Start it now and it runs like crap. We thought it was a piston ring, did a compression test. Compression is good. Now the sled also backfires when running. Do a full inspection on the engine, clutch, lines, carbs, etc... hope this helps.
