H
Well i just finished the install of my CPC stage 2 with redline gauge and at first it would not fire, traced down every connection and everything is plugged in where it was supposed to be plugged in and i pulled it over probly 30-40 times no dice, hooked up my jumper wire to the fuel pump and a 12v battery and you can hear it pressure up. pull it and it fires right up and idles at like 3200rpm and will not idle down and the redline gauge will not power up. Attitude box fires up, factory gauge powers up but still nothing so i can not tell what my fuel pressure is since it runs on the redline gauge. Talked to the guy i got it from and he said there are 2 wires i need to wire up to the factory gauge off the redline harness for it to power up.?
Any input will be apprciated
