I need one with bolts, PM me for ordering -payment
I also would be intersted in the plates and the stiffner bar for the hoop as a package deal!!! Work out a price and let us know what you are thinking!!!how about a package plates for the bulkhead and steering hoop support? you could call it the "real steering anti-slop kit"
I haven't Built the forward supports yet, so I don't know what to sell them for. How much do they go for else where and what is a fair price.
Wildchild sells a hoop support for $50, and ratsled (Steve Brandt) sells one for $100 or 110, can't remember. Two different designs.
Your Sled must be an 07, all the 08 and newer ones have 3 - 1/4" rivets that have to get drilled out and the 07 has 2 - 1/4" studs with 7/16" nuts on the bottom and hardly anything for a steering stop. This kit will also fix the over rotating handle bar problem on the 07.
I haven't Built the forward supports yet, so I don't know what to sell them for. How much do they go for else where and what is a fair price. Also, how beefy does everyone want them to be, Me and one of my fab guys was think 3/4" OD X .058 Chrome-moly, would be plenty. You don't want so stiff and heavy that if you crash real bad, it can't give away. As it is stock, you can already brake ribs, if you hit to hard.
Well I gues you dont need to worry about making a set of plate's for my 07, I had the sled up in the air the remove the belly pan to install my Dog Bone's, and i figured i would tighten the loose bolt on my steering post!!! You would be right if you said the stud snapped off while i was tighting it!!:smash:Your Sled must be an 07, all the 08 and newer ones have 3 - 1/4" rivets that have to get drilled out and the 07 has 2 - 1/4" studs with 7/16" nuts on the bottom and hardly anything for a steering stop. This kit will also fix the over rotating handle bar problem on the 07.
So i guess i will be fabbing my own plates while im in there replacing the broken bolt!!! So I see your plates in your pics have the 4 holes for the rivets, do you recommend this for my 07, or should i just stick with the 2 bolts that A/C designed??
Not what i planned on doing today, but i guess better in my garage than 25 miles back in the middle of bum F..K Egypt!!!
I will have it fabbed up tonight if i have the right size bolt's in my bin, I already have the 1/8" metal sitting on my work bench, and the sled tore apart, i dont have a new Miller 251 welder sitting in my garage for nothing:face-icon-small-winYou can still use his kit. I belive it replaces the stock two bolts anyway. Give him a call.
Jason
