9
So, I bought a 1994 Polaris XLT Special (40th anniversary if that means anything)
The short version:
Been riding the sled for about 200 miles since I bought it, went like hell, and am really happy with it.
The PO mentioned something about the top end being rebuilt, so I though to myself "Awesome, I wont have to touch it [the engine] for a long time."
Great, fast forward to now, and I melted down the stator side piston in a high speed pursuit of a Yamaha V-Maxx 700SX.
What caused the meltdown (determined from the teardown) is the fact that of the 8 studs holding the jugs to the crankcase, 5 of them managed to work themselves loose, causing a vacuum leak and thus going lean, thus causing the meltdown of the stator side piston.
The damage wasn't bad, no sleeve damage, just the piston. I was able to remove the aluminum transfer from the cylinder wall with 33% hydrochloric acid, and then hone it and it is good to go. $133 in parts later I am ready to rebuild.
My question is:
What are the factory carb settings for all of the adjustment screws in the machine. I want to douche out the carbs before I fire it, and that means messing with the settings on the screws.
The engine data is that it is a 3 cylinder 2 stroke with a 64mm (? I'm drunk @ this time) bore and a 60mm stroke, with 16mm wrist pins.
580cc? if the math serves me right.
@ any rate, the sled has triple mikunis, and again, I am wondering what the factory settings are for this motor, including those for the oil pump.
Any help is appreciated.
Yours truly, KMC
The short version:
My question is:
Yours truly, KMC
