Thanks for the help turbolover, What did you end up doing with the vac lines going up to the accs unit? Did you just vent them down under the carbs? I am having trouble with going from idle to WFO , it will stumble for a bit then clean out. It gets worst the longer it sits and idles. I am at 180 mains , 45 pilots, 2 turns out on air screw needle at 2.5 from top. if i follow a 99 600 xc they go with a 185 main and a 38 pilot. I am at 2200 feet and the sled will only be used in warmer conditions so i am thinking disconnect accs and run 38 pilot 180 main clip in #3 and start at 1 turn out on air screw.
