Water enters air box Arctic Cat M8 .Help
Dec 20, 2018
Hello.
I have a big problem.
When driving in deep, loose snow.
How to solve this problem?
Help please solve the problem
I will consider all your suggestions.
If possible with photos and links.
Coldfinger
538
Nebraska
I haven't looked at mine closely, 2010, but it seems to me like the only place snow could enter is thru the intakes on both sides and I believe there is one near the rear/center of hood.
The filter skin on the hood intakes should be intact. Next, I believe the black intake under the hood might have some foam around where it joins the hood, right behind the skins.
You might also put some more foam around the headlights to seal the gap. I notice my foam is so-so there as well.
I'm assuming stock intake plumbing/plastic is not cracked and the accordian boot is connected.
Dec 20, 2018
Everything can remove and make so?
1515920280855_default
1515927164736_default
on how many less will become snow?
Coldfinger
538
Nebraska
I dont know. Assumed you were stock but doesnt seem so.
So the filters must connect to an aftermarket boot which connects to airbox??
At this point, if snow is getting in somewhere, you must have a cracked boot or filters are not sealed to boot or filter has a tear or boot seal to throttle bodies is not sealed.
Dec 20, 2018
I got rid of the water. Pasted all seals, and installed an additional grid. Many thanks for the advice.
At the moment the problem.
When opening at full throttle, there is no traction, as if one cylinder is working, what could be the problem?
This problem periodically manifests itself. Brings terrible discomfort.
