Upgrade to Premium
Arctic Cat: M Series 2005-Current, all models in the M-series chassis
Reply
  #1
Old 09-07-2009, 03:42 PM
cat rider's Avatar
cat rider cat rider is offline
Currently: Not set.
cat rider has a reputation beyond reputecat rider has a reputation beyond reputecat rider has a reputation beyond reputecat rider has a reputation beyond reputecat rider has a reputation beyond reputecat rider has a reputation beyond reputecat rider has a reputation beyond reputecat rider has a reputation beyond reputecat rider has a reputation beyond reputecat rider has a reputation beyond reputecat rider has a reputation beyond repute
Garage
Default Bleeding brakes m8? Help!
Has anyone done this? Any suggestions? I can't seem to get the air out of the line.
Thanks
__________________
15' 800 Pro-RMK TD 155"
08' M8 SP 153"
Rate this post: Yes | No
  #2
Old 09-07-2009, 04:33 PM
hatchers hatchers is offline
Currently: desert dirt bike stuff
hatchers has a reputation beyond reputehatchers has a reputation beyond reputehatchers has a reputation beyond reputehatchers has a reputation beyond reputehatchers has a reputation beyond reputehatchers has a reputation beyond reputehatchers has a reputation beyond reputehatchers has a reputation beyond reputehatchers has a reputation beyond reputehatchers has a reputation beyond reputehatchers has a reputation beyond repute
Default
open the top res, fill her up, now crack the bottom line a bit, tighten it, pump the brake over and over, you will see bubbles come up, keep doing it until the bubbles stop.....then pump it a few more times, top it off, fasten down the cover and make sure the brake works
bleeding the brake line at the bottom works also.....but the other way requires no tools and works on everything
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to hatchers For This Useful Post:
Wrenchmaster (01-18-2017)
  #3
Old 09-07-2009, 05:04 PM
cat rider's Avatar
Currently: Not set.
Garage
Default
Thanks I got it!
__________________
08' M8 SP 153"
  #4
Old 09-07-2009, 05:19 PM
JHG JHG is offline
Currently: Not set.
JHG has a reputation beyond reputeJHG has a reputation beyond reputeJHG has a reputation beyond reputeJHG has a reputation beyond reputeJHG has a reputation beyond reputeJHG has a reputation beyond reputeJHG has a reputation beyond reputeJHG has a reputation beyond reputeJHG has a reputation beyond reputeJHG has a reputation beyond reputeJHG has a reputation beyond repute
Default
Quote:
Originally Posted by cat rider View Post
Thanks I got it!
Glad you got it! You can also go to a farm store and buy a large feeding syringe and piece of rubber hose that will fit on the bleeder on the caliper. Fill the syringe with brake fluid, take the cap off the reservoir then push the fluid through the system from the caliper bleeder screw(don't forget to open it). Go slow and when the res is full, the air will be out and you can close the bleeder then the res. Takes about 2 minutes, start to finish. I've done this with four wheelers too and it works really well and you don't need a power bleeder.
The Following User Says Thank You to JHG For This Useful Post:
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
no new posts
