2017 Switchback Assault Leaky Fuel Tank
alstar
137
71
North of Duluth, MN
Has anyone had an issue with this yet? Mine seems to leak a little, I noticed it was wet around the collar and under the plastic console.
  • 800-Switchback-Assault-144_SC_Orange_Pr-1000x401.pdf
HECKS
417
249
Sylvan Lake, AB
Silly question, but have you tried tightening down the collar ?
I had a few leak in the past out of the top of the gauge cover as well. Had to use apoxy.
alstar
137
71
North of Duluth, MN
We did tighten up the collar. Haven't been on it since to see if that will solve the problem or not. It will be covered under warranty but I was hoping that maybe it was just something as easy as that collar being loose. I'm mostly curious also to see if it was an issue that others have had.
XC500mod
218
72
I had RMK in the pro ride chassis that leaked like you are describing. Tightened the collar and the leaking stopped. I be this is the problem.
alstar
137
71
North of Duluth, MN
Rode it this weekend after tightening the collar up. It still leaked so I just dropped it off to get checked out. Hopefully it is something quick and easy to fix. Will let you know what was actually the issue.
