N
So just to clarify (maybe lol) - I had a look and my relays are SR1 - does that mean they are sealed??
Do most people put dielectric grease in all connections? Or just the connections for the relays, and spark plug boots. Personal preference or recommend to do all?
FWIW
Use the grease to help seal the connection.
Do not apply to the pins.
A copper based antiseize works well for the pins though.
Has anyone ordered from these sources yet??
I find this sentence / advice just wrong. All any formula of Anti-Seize is just metal particles suspended in a Grease. You won't (and Shouldn't) put Di-Electric grease on the pins but you will use essentially the same thing with copper particulate in it for the same purpose?
IMO; There would not be an issue if Polaris had specified / used tin plated connectors in the wiring harness to eliminate the non-conductive brass tarnish that is likely causing the majority of these issues. IMO there is little to nothing wrong with the relays, it is the non-conductive tarnish that is causing the issues. I would pull the connectors apart and replace the contacts with tin plated ones.
In my opinion; If you want a contact promoter use something that is designed for that purpose. Stabilitant 22 is by far the best I've found / used. It works miracles on questionable electrical contacts.
:Cry: extreme butthurt noted. First you were trying to disparage TAR now you're taking shots at another business. You sure drag a lot of drama around with you. Why not keep it on your website??A guy on hcs stole this idea from here and is selling them as his kits :face-icon-small-dis
http://redirect.viglink.com/?format...s://www.facebook.com/NorthstarPerformance137/Whats the link... is it a good price and good shipping?
Not sure if my link worked??? Check out NorthStar Performance on facebook. To answer your question ,,,yes the reviews and feedback Rick has gotten on HCS has been very positive.
Speaking of drama. Why do you follow Ratchit on 4 websites and constantly harass him? Do you not have a life?:Cry: extreme butthurt noted. First you were trying to disparage TAR now you're taking shots at another business. You sure drag a lot of drama around with you. Why not keep it on your website??
