Free up wasted horsepower and feel the efficiency of the SyncroDrive on your Ski Doo G4 model. We know from experience and feedback over the past few years with the aftermarket extended chain cases, that chain maintenance is especially critical to chain life. Chains are becoming a thing of the past! The belt drive systems will hold up to any horsepower you can throw at it. They are much more efficient than the chain drive with much less weight. Dropping about 3 lbs of rotating weight and 5 overall.
On top of the efficiency, choose from different gear ratio's, 2.17, 2.25, 2.33, 2.42, 2.52, 2.62 . Turbo, NOS, Big bore or whatever you choose we have the gear ratio to make your track rotate.
2.52 ratio is stock for a Summit (25/63)
Adjusting your belt is easy. Maximum belt life and maximum fun.
Don't let your buddies pass you by, unleash the power, check belt tension with your app, and burn gas. It's never been simpler or more reliable than it is today.
BELOW IS THE LINK TO THEM:
http://www.bd-xtreme.com/index.php?id_product=846&controller=product
