Upgrade to Premium
Ski-Doo: REV Sleds 2004.5-200, all models in the REV chassis
Reply
  #1
Old 10-11-2009, 06:15 PM
brahm brahm is offline
Currently: Braaaaaaaaaaaaap Pray for MORE snow!
Basic Member
brahm has a reputation beyond reputebrahm has a reputation beyond reputebrahm has a reputation beyond reputebrahm has a reputation beyond reputebrahm has a reputation beyond reputebrahm has a reputation beyond reputebrahm has a reputation beyond reputebrahm has a reputation beyond reputebrahm has a reputation beyond reputebrahm has a reputation beyond reputebrahm has a reputation beyond repute
Default 2007 800r R.A.V.E need help. (rave)
I decided I was going to clean up my R.a.v.e system today before the season starts (possibly Tuesday!!!) . I pulled one of them all apart, cleaned it and went to put it back together, and I can't for the LIFE of me get the larger metal ring (the one that seals the boot) back on. Whats the trick, or is it just some serious patients and a steady hand.
On a side note there was oil all over the place and a little carbon. Not sure how they are supposed to look when you pull them apart. There was even oil in the boot.
Rate this post: Yes | No
  #2
Old 10-11-2009, 06:29 PM
Basic Member
Default
part #12 in this image
//www.snowest.com/forum/attachm...4&d=1229102302
  #3
Old 10-11-2009, 09:22 PM
gman086 gman086 is offline
Currently: Killing IT!
gman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond repute
Default
To get spring back on, loop a tiewrap thru the band, put your first finger thru the loop, use your other hand to hold the wire band that you have started in place and continue around. If need to reseal bellows use copper RTV sealant first. Replace o-rings if oil in bellows.
Have FUN!
G MAN
The Following User Says Thank You to gman086 For This Useful Post:
brahm (10-11-2009)
  #4
Old 10-11-2009, 10:20 PM
Basic Member
Default
Quote:
Have FUN!
G MAN
Hey thanks, I ended up getting back on by rolling it off a spray can that I punched a hole in the bottom of (so the cap would sit flush with the can) It took HOURS to get it back on, cleaning and everything else took 15 mins. So if there was oil in the bellow I need to replace the o-ring..crap.. I guess that means I need to take it back apart again. I'll give the Zip tie trick a try this time around.. damn I was really hoping to never have to do that again. hahah. I also noticed some wear on the valves them selves. I'm thinking I should order up the 09 valve set, man it up and just replace them and the o rings.
  #5
Old 10-12-2009, 01:06 PM
Default
>>I'm thinking I should order up the 09 valve set, man it up and just replace them and the o rings.<<
For the '07 800R, yes, that would be a wise move!
Cheers,
G
brahm (11-04-2009)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
no new posts
