Upgrade to Premium
Ski-Doo: REV Sleds 2004.5-200, all models in the REV chassis
Reply
  #1
Old 10-20-2009, 08:39 AM
bobsled bobsled is offline
Currently: Not set.
Basic Member
bobsled is an unknown quantity at this point
Question Stuck in start up test mode?
Every once in a while after riding the deep stuff when I go to restart my rev it seems to get stuck in the start up test mode with the beeper on. It idles but won't go (bogs down). After shutting it down and restarting a few times it clears itself and is fine. Anyone out there had any similar problems? What do I check?
Rate this post: Yes | No
  #2
Old 10-20-2009, 09:35 AM
gus bohne gus bohne is offline
Currently: Not set.
Basic Member
gus bohne has a reputation beyond reputegus bohne has a reputation beyond reputegus bohne has a reputation beyond reputegus bohne has a reputation beyond reputegus bohne has a reputation beyond reputegus bohne has a reputation beyond reputegus bohne has a reputation beyond reputegus bohne has a reputation beyond reputegus bohne has a reputation beyond reputegus bohne has a reputation beyond reputegus bohne has a reputation beyond repute
Default
the rer switch is getting wet inside and needs to be replaced. the other issue can be one of the two relays that end to get moisture in them and then freeze up when the sled is shut down for short periods, the restarting gets the pipe heat to thaw the little tiny bit of ice in the relay and it releases.
get new relays too.
Gus
The Following User Says Thank You to gus bohne For This Useful Post:
bobsled (10-21-2009)
  #3
Old 10-20-2009, 09:42 AM
winter brew's Avatar
winter brew winter brew is offline
Currently: Not set.
winter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond repute
Default
And sometimes the tether connection will do this....loose fit or moisture.
The Following User Says Thank You to winter brew For This Useful Post:
  #4
Old 10-20-2009, 01:12 PM
Barton Barton is offline
Currently: searching for my lost shaker of salt and 06 Rev
Basic Member
Barton has much to be proud ofBarton has much to be proud ofBarton has much to be proud ofBarton has much to be proud ofBarton has much to be proud ofBarton has much to be proud ofBarton has much to be proud ofBarton has much to be proud ofBarton has much to be proud ofBarton has much to be proud ofBarton has much to be proud of
Default
I've had issues with the tether as well. I always carry my spare with me and just switch it out when I have this problem. Clears it up right away.
The Following User Says Thank You to Barton For This Useful Post:
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
no new posts
