Upgrade to Premium
Ski-Doo: REV Sleds 2004.5-200, all models in the REV chassis
Reply
  #1
Old 10-17-2009, 04:48 PM
brahm brahm is offline
Currently: Braaaaaaaaaaaaap Pray for MORE snow!
Basic Member
brahm has a reputation beyond reputebrahm has a reputation beyond reputebrahm has a reputation beyond reputebrahm has a reputation beyond reputebrahm has a reputation beyond reputebrahm has a reputation beyond reputebrahm has a reputation beyond reputebrahm has a reputation beyond reputebrahm has a reputation beyond reputebrahm has a reputation beyond reputebrahm has a reputation beyond repute
Default Vent Kit for Clutch Gaurd 07 Rev?
Does anybody make a vent kit for the plastic shroud that is attached to my clutch guard, I want to remove it so my clutch will stay cooler but I don't want to worry about snow getting between the belt and my clutch or reapplying duck tape to we plastic to fill in the stock body panel holes when I'm playing in the powder.
-Brahm
Rate this post: Yes | No
  #2
Old 10-17-2009, 06:43 PM
enis750 enis750 is offline
Currently: "Chain so big, can't pop my colla!"
enis750 has a reputation beyond reputeenis750 has a reputation beyond reputeenis750 has a reputation beyond reputeenis750 has a reputation beyond reputeenis750 has a reputation beyond reputeenis750 has a reputation beyond reputeenis750 has a reputation beyond reputeenis750 has a reputation beyond reputeenis750 has a reputation beyond reputeenis750 has a reputation beyond reputeenis750 has a reputation beyond repute
Default
dude just cut it off
99% of REV owners cut it off to keep the clutches cooler
I never have an issue w snow getting in
  #3
Old 10-17-2009, 07:43 PM
Basic Member
Default
It's gone, I didn't cut it, I just drilled out the rivets. I want to replace it though with a "mesh" version. My Mcat is the same way and when I pow turn to the left snow gets into the clutch area and causes the belt to skip.. I had to wrap the ****er with duck tape to stop that from happening lol.
  #4
Old 10-17-2009, 08:42 PM
bgraff1's Avatar
bgraff1 bgraff1 is offline
Currently: patiently waiting for snow
bgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond reputebgraff1 has a reputation beyond repute
Default
ive had mine off since the first day i bought it and have never had a problem.
  #5
Old 10-18-2009, 12:30 AM
CK1 CK1 is offline
Currently: Not set.
Basic Member
CK1 has much to be proud ofCK1 has much to be proud ofCK1 has much to be proud ofCK1 has much to be proud ofCK1 has much to be proud ofCK1 has much to be proud ofCK1 has much to be proud ofCK1 has much to be proud ofCK1 has much to be proud ofCK1 has much to be proud ofCK1 has much to be proud of
Default
yes ditch all plastic covers and foam in the engine compartment. Then use plastic door screen from Home Depot or SLP prefilter material to block off all openings on the side panels and hood. Use plumbers goop to glue them down, its clear and holds like cement.
The Following User Says Thank You to CK1 For This Useful Post:
JoHNI_T (10-19-2009)
  #6
Old 10-19-2009, 08:37 AM
Mod800R Mod800R is offline
Currently: beauty year!
Basic Member
Mod800R has a reputation beyond reputeMod800R has a reputation beyond reputeMod800R has a reputation beyond reputeMod800R has a reputation beyond reputeMod800R has a reputation beyond reputeMod800R has a reputation beyond reputeMod800R has a reputation beyond reputeMod800R has a reputation beyond reputeMod800R has a reputation beyond reputeMod800R has a reputation beyond reputeMod800R has a reputation beyond repute
Default
and throw a slp flowrite in the front section of the lh side panel, and take out your tool kit...
gets great airflow to your clutches, and cheap too
The Following User Says Thank You to Mod800R For This Useful Post:
  #7
Old 10-19-2009, 03:32 PM
907to406 907to406 is offline
Currently: Not set.
Location: Born & Raised in AK, Currently living and riding in Bozeman, MT
Basic Member
907to406 has a reputation beyond repute907to406 has a reputation beyond repute907to406 has a reputation beyond repute907to406 has a reputation beyond repute907to406 has a reputation beyond repute907to406 has a reputation beyond repute907to406 has a reputation beyond repute907to406 has a reputation beyond repute907to406 has a reputation beyond repute907to406 has a reputation beyond repute907to406 has a reputation beyond repute
Default
Also removed mine from the start and have never had an issue...i even have 1 1/4'' holes drilled behind my shock that aren't meshed and havn't had any problems with snow getting in. I'd highly suggest a JC custom vent kit as well if your looking for cooler clutches.
  #8
Old 10-19-2009, 08:20 PM
gman086 gman086 is offline
Currently: Killing IT!
gman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond reputegman086 has a reputation beyond repute
Default
http://frogzskin.com/index.php?main_page=index&cPath=1
Cheap solution for the budget minded.
Have FUN!
G
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
no new posts
