J
Hey guys,
I went to change out my track today, everything came out fine. When I put it back together it seems like I am short about 1/8" to be able to put everything back together on the secondary shaft. I tightened the nut as tight as I could, reinstalled the chaincase cover but when I put the collar with that little star bolt, the collar I am short on being able to put that key in so I can slide the brake rotor on.
I then took it all back off and tried to see if I could tap the shaft over further from the secondary clutch side, with no luck. I put it back together just to see and am still in the same boat.
Everything was fine when I took it apart so I was wondering if anyone has ran into this, is there any adjustment I need to be looking at? I'm a little confused at this point because I didn't change anything from disassembly to reassembly.
