2017 sidewinder 162 primary clutch breaks/track alignment help
Jan 13, 2019
8
so the bolt fell out of the spider and made a roller fall out causing the weight too break a piece of the Primary Sliding Sheave
any tips on removal of the clutch without tool would sticking a rod down the center and screwing a bolt into the threads of the Primary Fixed Sheave pop it out?
and having trouble aligning the front two rollers on the track any tips? one side keeps getting close to the edge its
up-high
299
83
71
Alberta Canada
park it outside and tip it on the right side. remove bolt and pour a little water in the hole. When it freezes it will push the clutch off.
