Upgrade to Premium
Ski-Doo: REV Sleds 2004.5-200, all models in the REV chassis
Reply
  #1
Old 01-03-2011, 09:23 AM
rob80168 rob80168 is offline
Currently: Not set.
rob80168 has a reputation beyond reputerob80168 has a reputation beyond reputerob80168 has a reputation beyond reputerob80168 has a reputation beyond reputerob80168 has a reputation beyond reputerob80168 has a reputation beyond reputerob80168 has a reputation beyond reputerob80168 has a reputation beyond reputerob80168 has a reputation beyond reputerob80168 has a reputation beyond reputerob80168 has a reputation beyond repute
Default '07 Big Time Bog
'07 800R Summit; SLP intake, SLP can, 3450 miles (has not been rebuilt) Milled head, all stock after that (including airbox). Riding @ 8,500 - 10,000 ft. Problem just started with this last ride, first time any issues with anything at all (4th season). I noticed a long warm up time needed for sled to stay running to put in reverse to get off trailer. A couple turns around the parking lot and it seemed to stay loaded up even after warming up. New plugs. Going down the trail @ 6,000 - 6,500 rpm , grab a handfull of throttle and a bog that was never there before. This happened all of the ride (25 miles). Some of the bogs were so bad that I almost went over the hood. Checked airbox to see if it had come off. Checked OK. Once it gets past the bog it has no problems getting to 8,200 - 8,300 rpm but then I had another issue there. Clamped throttle on a climb, running @ 8,000+ and it started to cut out, not like the low end bog. Looked @ new plugs back in parking lot and they were fine. The machine has always been a bit of a smoker @ lower rpm and oil use was a little more than other 800R's that I ride with but not overly. Fuel mileage has been fine. Everyone on our crew gets the fuel in the same place and I make a point to put isopropyl in every other fuel up (1/2 bottle). I will pull off the RAVE caps sometime in the next couple of days to see if they are gummed up but I doubt that is the problem. Before I decide to jet down and turn down the oiler I could use some input. The snow just got really good in NW Colorado and I don't want to miss any of it. Thanks
Rate this post: Yes | No
  #2
Old 01-03-2011, 01:09 PM
mastertech mastertech is offline
Currently: Balls Deep In Pow!!
mastertech has a reputation beyond reputemastertech has a reputation beyond reputemastertech has a reputation beyond reputemastertech has a reputation beyond reputemastertech has a reputation beyond reputemastertech has a reputation beyond reputemastertech has a reputation beyond reputemastertech has a reputation beyond reputemastertech has a reputation beyond reputemastertech has a reputation beyond reputemastertech has a reputation beyond repute
Default
If you up grade to a Premium Membership I will help you out!
  #3
Old 01-03-2011, 03:36 PM
bikerjustin bikerjustin is offline
Currently: Building a 770
bikerjustin has a reputation beyond reputebikerjustin has a reputation beyond reputebikerjustin has a reputation beyond reputebikerjustin has a reputation beyond reputebikerjustin has a reputation beyond reputebikerjustin has a reputation beyond reputebikerjustin has a reputation beyond reputebikerjustin has a reputation beyond reputebikerjustin has a reputation beyond reputebikerjustin has a reputation beyond reputebikerjustin has a reputation beyond repute
Default
I could care less if you buy a premium membership
Check your compression; The engine dying when going into reverse is a tell tale sign of low compression- I have read. Especially with that many miles, Whoa.
The Following User Says Thank You to bikerjustin For This Useful Post:
rob80168 (01-03-2011)
  #4
Old 01-03-2011, 04:28 PM
Default
I was being a smart aZZ...
  #5
Old 01-03-2011, 07:17 PM
Currently: Not set.
Default
What should the compression be?
  #6
Old 01-03-2011, 10:00 PM
Default
I don't know- equal to within 10% of each other. 135 to 175psi depending on wet or dry and elevation. If they are less than 100psi they are too low. Check it. Tell us what you get. It only takes 5 minutes or so. Do it with the engine cold. do it with the engine hot.
  #7
Old 01-03-2011, 10:07 PM
winter brew's Avatar
winter brew winter brew is offline
Currently: Not set.
winter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond repute
Default
Pull the caps off the exhaust valves and check for function.....they should suck in when you start the sled and pop out when you rev it up....then pop out all the way when you get on it hard.
Being a '07 I am always suspect of crank runout, check that. Should be less than .003". If it's up over .006" there's your problem.
The Following User Says Thank You to winter brew For This Useful Post:
  #8
Old 01-04-2011, 05:53 AM
Dynamo^Joe's Avatar
Dynamo^Joe Dynamo^Joe is offline
Currently: talking about clutching
Dynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond reputeDynamo^Joe has a reputation beyond repute
Default
Quote:
Originally Posted by rob80168 View Post
*Going down the trail @ 6,000 - 6,500 rpm , grab a handfull of throttle and a bog that was never there before.
*Clamped throttle on a climb, running @ 8,000+ and it started to cut out, not like the low end bog.
I have seen this over the years.
If you are full throttle and bog but let off to 4/5 throttle and 8200, then it could be the throttle position sensor has failed.
Have the dealer hook up to buds and get them to cycle all the sensors, it could be the tps.
__________________
Really good G4-850 and XM summit clutch kits
850 G4 Summit clutch kit index
Online Gear Calculator @ iBackshift
The Following User Says Thank You to Dynamo^Joe For This Useful Post:
rob80168 (01-04-2011)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Big time fail..... Thread Starter — Sapling-Thrasher Forum — Washington Replies — 1 Last Post — 11-06-2009 05:53 PM
Thread — I need some big time help!!!! Thread Starter — longhairfreak Forum — General Snowmobiling Replies — 20 Last Post — 03-31-2009 01:40 PM
Thread — Baker Delivers BIG TIME ! ! Thread Starter — Flakey Forum — Washington Replies — 24 Last Post — 01-05-2009 03:25 PM
Thread — First time to the Big Horns Thread Starter — Phil4Snow Forum — Wyoming Replies — 10 Last Post — 12-22-2008 08:52 PM
Thread — DOW Up Big Time. Thread Starter — weetee Forum — Fouled Plug Replies — 7 Last Post — 10-13-2008 02:51 PM
no new posts
