Upgrade to Premium
Performance/Modified Discuss modifications for your sled
  #1
Old 01-10-2010, 11:14 AM
SnowSnob SnowSnob is offline
Currently: Waiting for 2013 winter
Basic Member
SnowSnob has a reputation beyond reputeSnowSnob has a reputation beyond reputeSnowSnob has a reputation beyond reputeSnowSnob has a reputation beyond reputeSnowSnob has a reputation beyond reputeSnowSnob has a reputation beyond reputeSnowSnob has a reputation beyond reputeSnowSnob has a reputation beyond reputeSnowSnob has a reputation beyond reputeSnowSnob has a reputation beyond reputeSnowSnob has a reputation beyond repute
Default Strange Coolant Issue
This was the 1st season I didn't summerize my sled and I did the old start the sled once a month thing. I WAS going to pull the motor and go over it and clean the sled but I just ran out of time this summer.
When I went to get her up and running for the season I noticed I had lost some coolant in the bottle. I filled it up and when I went to pull it over I could watch the coolant level go down with every pull???? I could hear the bottle pressurizing because it was hissing so I would turn the cap and the fluid would pop back up.
I ran the sled and thought I got the coolant level to stabalize, I even got the front end up and blead it just incase it was an air bubble....not sure how an air bubble could get in the system just sitting there all summer???
Went for a ride and I could not keep coolant in it. It SEEMED like it was all coming out the overflow but I would not bet on that. Check all hose clamps to make sure one didn't come loose. Still had the same pressurizing issue and would have an empty bottle until I turned the cap and the coolant level would come up a little. I dumped A LOT of water in to get me back and seemd like I was loosing it faster then I could put it in but there was no obvious leakage anywhere.
If I had a hole somewhere would it be able to pressurize like that?
It seems like air lock but I just don't understand how it happened from just sitting in the garage.
Thanks for any help
Rate this post: Yes | No
  #2
Old 01-10-2010, 11:45 AM
cascadesnowjunky's Avatar
cascadesnowjunky cascadesnowjunky is online now
Currently: doing the snow dance
cascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond reputecascadesnowjunky has a reputation beyond repute
Default
Sounds to me like maybe a o-ring in the head (head gasket), if every time you pull the rope and the system starts to pressurize then I would think that cylinder pressure is being pushed in. Do you see any black oily residue in the antifreeze, that is another indication of leaking o-rings.
  #3
Old 01-10-2010, 01:55 PM
Basic Member
Default
The motor has been rebuilt recently...two seasons ago.
It ran just fine on the last ride. It must have happened when I started it up last just to get things circulating but it was only for a min. or 2
  #4
Old 01-10-2010, 02:23 PM
Scott's Avatar
Scott Scott is offline
Currently: ACTIVELY defend your right to ride.
Polaris & Montana Moderator
Scott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond repute
Garage
Default
He did ask a really good question though...look inside your antifreeze bottle. Is there a grey/black color in there or is is clear and green?
__________________
OEM parts from Free Agent
Honestly, Honey!!! The shop paid for these mods. They sponsor me now. Really!
Ambassador for:
FB & IG: Scott Stiegler
Check out these cool products:
  #5
Old 01-10-2010, 06:51 PM
Basic Member
Default
It is clear and green.
Just tore about half the seld, took off the seat to get to the hoses running to the rear exhanger...no coolant in the hoses, took off the hose that goes into the head...no coolant. Lifted the front up reattached everything good and tight filled with coolant and in seconds came exploding out the bottle.
Took head off....no coolant. ONLY thing I can thing of is the water pump went out and therefore the engine is pumping air through the system and this is why I'm having the pressurizing issue.
What typically happens when a water pump goes out?
  #6
Old 01-10-2010, 09:51 PM
Idcatman1's Avatar
Idcatman1 Idcatman1 is offline
Currently: Not set.
Idcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond reputeIdcatman1 has a reputation beyond repute
Default coolant
A bad water pump would not pressurize the system, I agree with guy who suggested leaky o ring head gaskets. The cylinder compression blows into the cooling system and blows the coolant out the overflow on your bottle. I have seen it plenty of times. I guess a bad water pump could let your engine overheat enough to cook the o rings though so you should check both.
  #7
Old 01-10-2010, 10:35 PM
poorider poorider is offline
Currently: wrench ride repeat
Basic Member
poorider has a reputation beyond reputepoorider has a reputation beyond reputepoorider has a reputation beyond reputepoorider has a reputation beyond reputepoorider has a reputation beyond reputepoorider has a reputation beyond reputepoorider has a reputation beyond reputepoorider has a reputation beyond reputepoorider has a reputation beyond reputepoorider has a reputation beyond reputepoorider has a reputation beyond repute
Default
No doubt it is a leaky head gasket, do not run the sled any more!! You will cause some serious damage without coolant in the head. It is a cheap fix as long as you didn't overheat or warp anything. Change the o-rings and the gasket then fill her back up and run it, and make sure the water pump is actually circulating coolant
  #8
Old 01-11-2010, 10:36 AM
Basic Member
Default
I pulled the head off and the o-rings seem ok and so does the outter rubber gasket?
Is it not obvious or something?
It would be nice if it wasn't the water pump since I would probably have to pull the motor to change the impeller.
  #9
Old 01-12-2010, 08:18 AM
BB454 BB454 is offline
Currently: Not set.
Basic Member
BB454 has a reputation beyond reputeBB454 has a reputation beyond reputeBB454 has a reputation beyond reputeBB454 has a reputation beyond reputeBB454 has a reputation beyond reputeBB454 has a reputation beyond reputeBB454 has a reputation beyond reputeBB454 has a reputation beyond reputeBB454 has a reputation beyond reputeBB454 has a reputation beyond reputeBB454 has a reputation beyond repute
Default Coolant
If you are talking Polaris big block. Take the oil pump off and pull the motor over by hand, if the oil pump drive moves then the belt is OK. They will overheat almost immediately if the belt is broken. They will also blow coolant out of the tank because it is boiling while the coolers remain cold. Next check the thermostat, seen them fail pretty often. Drop it in a pan of hot water. Last year I got a bad one right from the dealer.
If belt and thermostat is OK then you will need to look at the WP impeller. They are known for the nut that hold them on coming loose and not circulating water very well if at all. Did a 03 Saturday. You can do it without pulling the motor. Remove the 2 clamp blocks on the motor that hold the water manifold on under the Y pipe. These are held by 2 Allen screws. WP cover is held on by 5 10mm bolts.
  #10
Old 01-12-2010, 08:38 AM
Basic Member
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
no new posts
