Upgrade to Premium
Polaris: TURBO Turbo discussion for Polaris aftermarket turbo sleds
Reply
  #1
Old 02-02-2019, 06:41 PM
80arrow's Avatar
80arrow 80arrow is offline
Currently: thinking about the snowies :-)
80arrow has a reputation beyond repute80arrow has a reputation beyond repute80arrow has a reputation beyond repute80arrow has a reputation beyond repute80arrow has a reputation beyond repute80arrow has a reputation beyond repute80arrow has a reputation beyond repute80arrow has a reputation beyond repute80arrow has a reputation beyond repute80arrow has a reputation beyond repute80arrow has a reputation beyond repute
Default octane??
This may be a dumb question but how do you know if you are running to high of octane for the boost you are running??
Rate this post: Yes | No
  #2
Old 02-03-2019, 06:18 AM
xpspenziv's Avatar
xpspenziv xpspenziv is offline
Currently: boooasting
xpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond reputexpspenziv has a reputation beyond repute
Default
Your gas mileage will suffer. The inability of your engine to burn the higher octane gas correctly will cause your engine to produce less power and thus will require more fuel to perform at the same level. High octane has or fuel has a slower burn rate. Benefit is it will help the engine run cooler. If your way to high it'll sputter spit and fart. It can also knock the spark plugs and out.
How much boost are you running? @ what elevation?
  #3
Old 02-03-2019, 07:57 AM
80arrow's Avatar
Default
I'm going to try to run 6-7 pounds of boost at 5-7000 feet. The sled was set-up for the Snowies and 10-12 pounds of boost. I've never rode at this lower elevation and I'm trying to come up with an idea for tuning. I have the chart for the Silber turbo for mixing race fuel and premiun and also for the clutching recommendations but I'd also like to know what to look for.
  #4
Old 02-03-2019, 11:09 AM
tjulius tjulius is offline
Currently: Not set.
Basic Member
tjulius is an unknown quantity at this point
Default
7lb spring is closer to 10lbs according to buddy with boost guage. I ran 5lb spring around big horns on 1/3 e50 and 91 and it ran great. Too much octane or av gas will make it boggy until you get on the boost
The Following 2 Users Say Thank You to tjulius For This Useful Post:
80arrow (02-03-2019), BigAir (02-03-2019)
  #5
Old 02-03-2019, 11:18 AM
80arrow's Avatar
Default
I'm running a boost gauge. This is the first time I've adjusted the boost or clutching since I got it. I'm kinda lost, lol. I'll give Silber a call tomorrow morning I think also.
  #6
Old 02-03-2019, 11:52 AM
Octanee Octanee is offline
Currently: Not set.
Octanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond repute
Default
I can get 94 octane pump gas at chevron, At 4k feet 5# it's fine 6k feet 7-8# it was fine.
  #7
Old 02-03-2019, 01:56 PM
gmustangt's Avatar
gmustangt gmustangt is offline
Currently: Not set.
gmustangt has a reputation beyond reputegmustangt has a reputation beyond reputegmustangt has a reputation beyond reputegmustangt has a reputation beyond reputegmustangt has a reputation beyond reputegmustangt has a reputation beyond reputegmustangt has a reputation beyond reputegmustangt has a reputation beyond reputegmustangt has a reputation beyond reputegmustangt has a reputation beyond reputegmustangt has a reputation beyond repute
Default
Quote:
Axys? What kit?
  #8
Old 02-03-2019, 05:32 PM
Currently: Not set.
Default
Quote:
Originally Posted by gmustangt View Post
Axys? What kit?
Boost it, 2011 pro rmk, has a water to air intercooler.
  #9
Old 02-03-2019, 10:44 PM
sledhead9825 sledhead9825 is online now
Currently: Not set.
sledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond reputesledhead9825 has a reputation beyond repute
Default
Hold on a second... You have been posting in other threads about Det issues. I had a 13 Boost it Pro running 7Lbs and a water2air intercooler. At 6000 ft there is no way it was running on pump gas. If you have a Boost-it Pro running on pump fuel your the only one. Or maybe we cured your Det problem. It won't run on pump gas.
  #10
Old 02-03-2019, 10:59 PM
Currently: Not set.
  #11
Old 02-04-2019, 12:59 AM
kgra kgra is offline
Currently: Not set.
kgra has a reputation beyond reputekgra has a reputation beyond reputekgra has a reputation beyond reputekgra has a reputation beyond reputekgra has a reputation beyond reputekgra has a reputation beyond reputekgra has a reputation beyond reputekgra has a reputation beyond reputekgra has a reputation beyond reputekgra has a reputation beyond reputekgra has a reputation beyond repute
Click Here to Register
  #12
Old 02-04-2019, 09:57 AM
Currently: Not set.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 88 Octane NO Ethanol or 91 Octane with 10%? Thread Starter — aerochip Forum — Ski-Doo: XM Sleds Replies — 8 Last Post — 01-05-2015 11:59 AM
Thread — 91 Octane Ethanol or 88 Octane+Race Fuel Blend Thread Starter — M8 Rider Forum — Arctic Cat: M Series Replies — 1 Last Post — 12-16-2012 03:56 PM
Thread — What octane? Thread Starter — spray25 Forum — Arctic Cat: TURBO Replies — 2 Last Post — 01-19-2012 12:02 PM
Thread — getting 91+ octane Thread Starter — alaskanadams Forum — Alaska Replies — 8 Last Post — 01-05-2010 06:15 PM
Thread — octane Thread Starter — DOOMAN Forum — Yamaha Replies — 2 Last Post — 12-27-2008 07:02 PM
no new posts
