Upgrade to Premium
Polaris: IQ 2005-current, all models in the IQ and IQ Raw chassis
Reply
  #1
Old 12-16-2018, 09:05 PM
TRIPLESWILLNEVERDIE!'s Avatar
TRIPLESWILLNEVERDIE! TRIPLESWILLNEVERDIE! is offline
Currently: Boosted
TRIPLESWILLNEVERDIE! has a reputation beyond reputeTRIPLESWILLNEVERDIE! has a reputation beyond reputeTRIPLESWILLNEVERDIE! has a reputation beyond reputeTRIPLESWILLNEVERDIE! has a reputation beyond reputeTRIPLESWILLNEVERDIE! has a reputation beyond reputeTRIPLESWILLNEVERDIE! has a reputation beyond reputeTRIPLESWILLNEVERDIE! has a reputation beyond reputeTRIPLESWILLNEVERDIE! has a reputation beyond reputeTRIPLESWILLNEVERDIE! has a reputation beyond reputeTRIPLESWILLNEVERDIE! has a reputation beyond reputeTRIPLESWILLNEVERDIE! has a reputation beyond repute
Garage
Default Power up connection for tps test
07 700 dragon trying check tps setting found connector near shock tower with red/white wire and brown wire at the connector. When engine is running Im getting 14v at connector so I assume this would be the correct connector to jumper 12v power in for tps?
Rate this post: Yes | No
  #2
Old 12-16-2018, 10:33 PM
richracer1's Avatar
richracer1 richracer1 is offline
Currently: Doing the Sidekick Switch
richracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond reputerichracer1 has a reputation beyond repute
Default
Quote:
No that is the DC power test connector. It will not power the ECU. Look for a connector next to it that has an orange (+) and brown (-). It should state external power (EXT PWR) or ECU PWR.
__________________
The Following User Says Thank You to richracer1 For This Useful Post:
TRIPLESWILLNEVERDIE! (12-17-2018)
  #3
Old 12-16-2018, 11:57 PM
Currently: Boosted
Garage
Default
There is also a red and brown on a smaller connector and a connector with three wires an orange a black/white and a black.
none of the three connectors at the shock tower are labeled at all whatsoever on my 07
If someone had a pic of an 08 and up I could compare with that would be helpful. I'm thinking 07 is a bit different.
  #4
Old 12-17-2018, 12:03 AM
richracer1's Avatar
Default
I believe it's the connector with the 3 wires. The orange wire should mate up with the red wire on the power up cable. If you can wait, I double check the wiring schematic again tomorrow to make sure.
__________________
  #5
Old 12-17-2018, 12:19 AM
Currently: Boosted
Garage
Default
These are the other two connectors
  #6
Old 12-17-2018, 04:55 PM
Currently: Boosted
Garage
Default
Quote:
Yep that one works to power up ecu. Got my tps set no problem.
Thank you for the help. I went ahead and took a little mini sharpie and labeled all three of the connectors now that I know what they are all for.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 09 M8 xtra connection on PTO side ECU connection Thread Starter — Burns1980 Forum — Arctic Cat: M Series Replies — 3 Last Post — 11-19-2010 12:03 PM
Thread — KOSO EGT gauge power connection Thread Starter — cat rider Forum — Arctic Cat: M Series Replies — 13 Last Post — 11-16-2010 01:55 AM
Thread — 2005 m6 Where to get power connection? Thread Starter — Letitsnow800r Forum — Arctic Cat: M Series Replies — 0 Last Post — 12-06-2009 12:25 PM
Thread — How do I test my DPM and TPS? Thread Starter — JamesS Forum — Ski-Doo Replies — 2 Last Post — 02-25-2009 10:52 PM
Thread — digatron power/tach connection M1000 Thread Starter — Steamboy Forum — Arctic Cat Replies — 1 Last Post — 12-11-2007 11:15 PM
no new posts
