M
I'm looking for primary clutch weight recommendations. Any help would be great. Make it "allegedly" if you like.
I have:
Bender Pipes
Drilled Air Box
Reed Spacers
Stock secondary helix
Stock secondary spring (forget what it is)
19/40 gears
Currently 8CR weights with 10.3 Al on inside, 13.3 steel on outside hole nearest the tip.
I ride 8000 - 10,000 ft. (Cooke, Snowy, Tog)
151" - no extro-verts.
G-W-G primary spring
I have not yet called Hartman Inc. or Mountain Performance. I just put a 151" put on it form MPI, so I'll call them first since I already gave them my business.
My buddy has the exact setup except, 156" track and his 13.3 steel is on the inside, and his 10.3 Al is on the outside hole nearest the tip. He says it runs good.
TJ in Alpine, WY originally set this up 2 seasons ago, but I was stock and 141" and did not have the Benders on it at that time. It is my understanding that he sold the dealership, and is only doing heavy mod stuff with the strokers, so I haven't bothered him yet with little ol' me and my beat up old MM700.
Again, any help would be great, thanks.
Eric
I have:
Bender Pipes
Drilled Air Box
Reed Spacers
19/40 gears
Eric
