how do you calibrate pcv tps with a battery
G
glaciermonkey
158
12
18
skidro willey, wa
does anyone know where i connect the battery to calibrate my pcv tps? 9 volt?
i know how to do it with the sled running, just don't want to smoke out the shop
09 m8
thank you
power commander v throttle position calibration
To set the TPS calibration in the PCV without the machine running, you will need the OEM Arctic Cat diagnostic tool to power up the ECU. This powers up the sled and all sensors as well as the PCV. The TP calibration in Control Center software will then read the true voltage from the TPS sensor signal seen during normal operation.
~T.J.
Griff
162
~T.J.
Can't beat the tech support on Snowest! Kudos.
D
diggerdown
3,452
677
Deer Park Wi.
You need the specs. You do not do it with the engine running. You need to feed it 5 volts, so you need a 5 volt resister. You need a good fluke meter to read the voltage.
