New to E-TEC, have a few ?'s...
J
Feb 15, 2003
483
31
Greenfield, MN(55357)
Hey all,
Coming from a 2008 Summit 154" 800R to a new XM, I had a few questions regarding the change....
1) I ran the semi-synthetic Ski-Doo oil in my 800R and was wondering if this is also sufficient for the 800 E-TEC.
2) I had a HPS muffler/can on the 800R and was looking for suggestions on which canisters have worked well on the 800 E-TEC sleds.
Thanks all,
-John
jdog1
582
381
I have ran semi for 2 years in mine with no problems. Hps seems to be the can of choice.
winter brew
4,332
LakeTapps, Wa.
I would run the full synthetic. No reason not too, these things use a lot less oil than your '08 did and there will be no questions if you ever need warranty work since full synthetic is the recomended oil. I'm sure there are a thousand oils that will be fine but why bother is my opinion.
SLP and HPS are always good choices.
cubby
499
83
I run full syn in mine also but when I looked at the sticker on the side of my oil tank it says to run the blend, so I don't know if you could get in trouble with a dealer if it came down to it but I was told by my dealer to run the full syn.
cubby
499
83
Go to Big John's web site and buy from him he has a good price. $350+ shipping
sledheadracing.com I think.
wwracer
1,090
924
Island Park ID
It's the dangest thing... that sticker. Factory requires FULL synthethic to meet warrenty requirments, but when replacing broken/damaged oil tanks they ship replacements with the same wrong sticker:face-icon-small-con
cubby
499
83
Sorry but this machine was boughten brand new from myself with .2 miles on it. So it has not been replaced and there are a lot of others out there that say theirs say the same thing, so I'm not sure about the replacement ones cause I've never seen one.
R
rmk01r1der
Apr 30, 2008
321
ND
Run full. From what I've read HPS and SLP are the 2 leaders for the Etec. HPS you lose more weight but its loud. SLP meets noise regulations but isn't as light as HPS. Either seems like a good choice IMO
D
dropitbuster
130
69
Terrace B.C.
Pre-mix?
Do you have to run pre-mix in the first tank or is this taken care of by the computer during the break-in period? How long is the break-in again?
wwracer
1,090
924
Island Park ID
I understand that, the point is the sleds were shipped new with the wrong stickers, and they still provide the wrong info on the replacement part... not a big deal really but in the warranty world it could give a customer some wiggle room if using the "wrong oil"
M
mtn mike on boost
291
83
Woodinville,WA
Should be noted, you will probably need to wear earplugs with the CF can.
Thats what i would have thought because of the design, but my buddy has one on his xp and i was suprised how reasonable the sound level was.
Does the packing need to be changed regularly to keep the levels down?
