I just bought my first snowmachine and I got a good deal because the PO couldn't put it back together. Because I didn't take it apart I have a few questions that I couldn't find in the FSM or on Google. The oil tank has a black rubber hose that was cut and there is also a cut black rubber hose on a pump on the triangular bracing. Does it go there? I have a clear oil feed line from the pump, where does that go, I thought it went to the tank? Where do I hook up these exhaust guillotines, is this a vacuum line? I can tell that the fuel line with the filter is the supply, but I don't see how to tell which port on the fuel rail is supply and which is return.
