Upgrade to Premium
Ski-Doo: REV Gen 4 For the 2017 and newer REV Gen 4 Sleds
Reply
  #1
Old 09-30-2018, 12:14 PM
TWARD700's Avatar
TWARD700 TWARD700 is offline
Currently: Sled is almost ready just need snow!!
TWARD700 has a reputation beyond reputeTWARD700 has a reputation beyond reputeTWARD700 has a reputation beyond reputeTWARD700 has a reputation beyond reputeTWARD700 has a reputation beyond reputeTWARD700 has a reputation beyond reputeTWARD700 has a reputation beyond reputeTWARD700 has a reputation beyond reputeTWARD700 has a reputation beyond reputeTWARD700 has a reputation beyond reputeTWARD700 has a reputation beyond repute
Default 850 stock exhaust heat shield
Has any one removed the heat shield and ceramic coated the pipe? My heat shield rattles making lots of noise. Wondering if it will cause more under hood heat or decrease it.
__________________
2008 SKID00 REV XP TURBO PERFORMANCE GARRETT KIT 10 LBS ON AVGAS 174 2.5 ICE AGE RAILS FOX EVOL X's EVOLUTION AIR SUSPENSION BRTECH HEADLIGHT DELETE POLISHED TUNNEL LOTS OF POWDERCOATING CAMO GRAPHICS http://s611.photobucket.com/albums/tt197/Tward700
Rate this post: Yes | No
  #2
Old 09-30-2018, 09:10 PM
TreeThrasher TreeThrasher is offline
Currently: Not set.
Basic Member
TreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond reputeTreeThrasher has a reputation beyond repute
Default
Iíd bet dollars to donuts that the stock heat shield will outperform thermal coating handily
  #3
Old 09-30-2018, 09:22 PM
TWARD700's Avatar
Default
It isnít to expensive to buy new heat Shields.
__________________
  #4
Old 09-30-2018, 09:29 PM
Currently: Not set.
Basic Member
Default
Ya itís just tough to beat a heat shield wiTh an insulation layer under it. I used to header wrap the pipes and that worked well but itís ugly.
  #5
Old 09-30-2018, 10:08 PM
venom1000's Avatar
venom1000 venom1000 is online now
Currently: waiting on parts
venom1000 has a reputation beyond reputevenom1000 has a reputation beyond reputevenom1000 has a reputation beyond reputevenom1000 has a reputation beyond reputevenom1000 has a reputation beyond reputevenom1000 has a reputation beyond reputevenom1000 has a reputation beyond reputevenom1000 has a reputation beyond reputevenom1000 has a reputation beyond reputevenom1000 has a reputation beyond reputevenom1000 has a reputation beyond repute
Default
100% gonna be more under hood heat. The issue that I c is with the front exhaust support bracket. The exhaust bracket is a part of the heat shield. So either run without it or get a new one fabed up.
__________________
2019 summit x 165
2015 summit xm t3 with BD tial/intercooler kit, raptor shocks, lime nine wrap.(sold)
  #6
Old 09-30-2018, 10:25 PM
i'llDooit i'llDooit is online now
Currently: summer sucks
i'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond reputei'llDooit has a reputation beyond repute
Default
Ceramic makes for a bit of performance, but I would still run the heat shield as well if it still fits
  #7
Old 09-30-2018, 10:42 PM
ak ak is online now
Currently: Nothing
ak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond repute
Default
If you went a true ceramic like swain coating, itís about the same as the stock heat shield. my 850 has the slp pipe / diamond s can with there ceramic coating I only installed extra heat tape on the front nose pan. So far no melting has happened yet.
  #8
Old 09-30-2018, 10:52 PM
TWARD700's Avatar
Default
https://www.performancecoatings.com/exhaust-coating
Are the guys I have used in the past
__________________
  #9
Old 09-30-2018, 11:36 PM
ak ak is online now
Currently: Nothing
Default
Probably no different then the slp coating.
  #10
Old 10-01-2018, 04:55 AM
IcutMetl IcutMetl is offline
Currently: Not set.
Basic Member
IcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond repute
Default
Quote:
Exactly!
Every other ceramic coating will appear purely decorative after having had components coated with SwainTechís White Lightning. Itís very thick in comparison, and almost abrasive to the touch due to the way itís deposited.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Exhaust Pipe Heat Shield Options Thread Starter — PowderGirl Forum — Snow bikes Replies — 2 Last Post — 10-06-2016 12:29 PM
Thread — exhaust pipe cover / heat shield cracked 2010 M8 Thread Starter — WFOWA Forum — Arctic Cat: M Series Replies — 7 Last Post — 01-10-2014 06:37 PM
Thread — Exhaust Heat Shield Thread Starter — Weatherbyman Forum — Polaris: 900 Replies — 7 Last Post — 01-20-2010 09:44 AM
Thread — TRX-1 Exhaust Heat Shield? Thread Starter — air4ce1 Forum — Yamaha Replies — 0 Last Post — 02-26-2009 09:44 PM
no new posts
