If this was done, would it need a new flash on the ECU?
you must have the porting to the cylinders and the reflash to use the 06 pipe on an 05
Just wondering why no one here speaks of Dyno Port? I have Y/pipe/can and runs great! Just wondering? Is it a "west thing" 'cause you all live by SLP?
I just asked a simple question, no need to get all up in a bunch. Just a simple question that's all. I have friends that have SLP products and so do I.What's wrong with supporting your local business?
Because SLP is in Idaho "in the mountains", tests there stuff "in the mountains" and does R&D for Polaris, "in the mountains". Their pipes flat work for the 900. When we ride, we may have altitude swings of 3,4,5, maybe even 6 thousand feet.
Before you tell us what the SLP pipe did on the dyno 4 and a half years ago, I'll remind you to check the BSFC's that particular day LMAO. Not only that, but the SLP pipe makes its power at 7,800 not the 7,200 they were trying to tune for.
I've had plenty of dynaport pipes and cans on skidoo's. I quit using their cans after I had 3 of them in one season that would loose baffles (they look like a chinese star) and cause horrible engine runnablity problems. Had to leave a sled on the mountain when the first one went down before I figured out what was causing the sled to sputter and not rev up over 4,500 RPM's. Needed a chopper ride the next day as it was in an area that you just can't tow a sled out of.
