Upgrade to Premium
Yamaha: Boosted Sleds (Turbo or Supercharged) Turbo discussion for Yamaha aftermarket Turbo or Super Charged sleds.
Reply
  #1
Old 01-09-2017, 06:30 PM
goofy goofy is offline
Currently: Not set.
Basic Member
goofy has a reputation beyond reputegoofy has a reputation beyond reputegoofy has a reputation beyond reputegoofy has a reputation beyond reputegoofy has a reputation beyond reputegoofy has a reputation beyond reputegoofy has a reputation beyond reputegoofy has a reputation beyond reputegoofy has a reputation beyond reputegoofy has a reputation beyond reputegoofy has a reputation beyond repute
Default Talk to me abut 4th injector
I am looking at a 2015 viper that is set up with larger inter cooler, fuel pump upgrade and a 4th injector. Currently they have only ran 110 race fuel. I am not interested in running 110 so would drop the boost and run 91 but how does that exactly work? All injectors still work? Still run good running at 91 and lower boost. Just feeling it out. Maybe just look for a standard 180 kit? It does have a pro logger to adjust boost
Rate this post: Yes | No
  #2
Old 01-10-2017, 12:46 PM
madsledder madsledder is offline
Currently: Not set.
Basic Member
madsledder has a reputation beyond reputemadsledder has a reputation beyond reputemadsledder has a reputation beyond reputemadsledder has a reputation beyond reputemadsledder has a reputation beyond reputemadsledder has a reputation beyond reputemadsledder has a reputation beyond reputemadsledder has a reputation beyond reputemadsledder has a reputation beyond reputemadsledder has a reputation beyond reputemadsledder has a reputation beyond repute
Default
How much boost is it running? Does it have a head shim?
Could look at the evo reflash for a little more on stock compression since it has the forth injector.
  #3
Old 01-10-2017, 12:47 PM
Currently: Not set.
Basic Member
Default
Or just do a head shim if it doesn't have it. Then its still setup.
  #4
Old 01-10-2017, 07:02 PM
Currently: Not set.
Basic Member
Default
I don't know what boost they were running but basically wanted to know if I drop boost to say 7 lbs and run 91 octane will it run fine with all the upgraded stuff? It's got a lot of upgrades for high boost but don't really want it. It's just a good deal. Only 300 or so miles.
  #5
Old 01-10-2017, 10:01 PM
up-high's Avatar
up-high up-high is offline
Currently: New femur and a new knee and more metal in hip!!
up-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond repute
Default
Might as well buy some 110. Boost is addicting. If it's set up to run high boost it will be fine at 7 lbs on 91(ask the owner to be sure). You won't leave it at 7 very long. Viper rods have a problem with high boost(heard this on the internet so must be true).
__________________
65/121 It don't get any lighter!
BERRGG
It's Mountainhorse time now!!!
  #6
Old 01-10-2017, 10:56 PM
Octanee Octanee is offline
Currently: Not set.
Octanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond repute
Default
Well If I remember right, the nytro ran like 7 psi on pump gas did they not? and the viper has the nytro engine, so it should be all the same gig. If you want good horsepower on pump gas, the head shim is a must, race gas costs lots, a little time to put in the head shim and on pump gas you'll be up and beyond on pump gas vs that of race gas with stock compression.
  #7
Old 01-11-2017, 08:25 AM
Motorbreath_ Motorbreath_ is offline
Currently: Shoveling snow! :D
Basic Member
Motorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond reputeMotorbreath_ has a reputation beyond repute
Default
Quote:
That's only the 2016 models.. and only a few were affected. Kind of like Russian roulette.. 14 and 15 models can handle boost no problem.
  #8
Old 01-11-2017, 06:27 PM
Currently: Not set.
Basic Member
Default
I need to understand the head shim thing I guess. So the deal is you have someone do a head shim and you can run the same boost with 91 Oct vs 110 oct? Ya not interested at all running 8 dollar per gallon fuel. I run a nytro with turbo 7 lbs of boost and I love it. Not saying more isn't better!
  #9
Old 01-11-2017, 07:29 PM
Currently: Not set.
Default
Quote:
Well the head shim lowers compression, So IIRC, the nytro is 7 psi ish on pump gas, and is ~180 hp? 190? then you go with a head shim, ~270 horse @ 15#? on pump all day every day.
  #10
Old 01-21-2017, 12:01 AM
aj1180 aj1180 is offline
Currently: Not set.
aj1180 has a reputation beyond reputeaj1180 has a reputation beyond reputeaj1180 has a reputation beyond reputeaj1180 has a reputation beyond reputeaj1180 has a reputation beyond reputeaj1180 has a reputation beyond reputeaj1180 has a reputation beyond reputeaj1180 has a reputation beyond reputeaj1180 has a reputation beyond reputeaj1180 has a reputation beyond reputeaj1180 has a reputation beyond repute
  #11
Old 01-21-2017, 06:55 PM
Currently: Not set.
Basic Member
Click Here to Register
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — April 4th Thread Starter — FCR112 Forum — Colorado Replies — 0 Last Post — 04-03-2013 08:42 PM
Thread — 4th Marriage Thread Starter — allied1 Forum — Fouled Plug Replies — 3 Last Post — 04-10-2012 08:56 AM
Thread — What everyone doing for the 4th ? Thread Starter — Aldrich Forum — Fouled Plug Replies — 15 Last Post — 07-03-2009 03:23 PM
Thread — 69 longhorn im just abut done with Thread Starter — speeddemon Forum — Fouled Plug Replies — 17 Last Post — 10-14-2008 09:14 PM
no new posts
