Upgrade to Premium
Yamaha: Boosted Sleds (Turbo or Supercharged) Turbo discussion for Yamaha aftermarket Turbo or Super Charged sleds.
Reply
  #1
Old 12-08-2016, 01:10 PM
maxeater maxeater is offline
Currently: Not set.
maxeater has a reputation beyond reputemaxeater has a reputation beyond reputemaxeater has a reputation beyond reputemaxeater has a reputation beyond reputemaxeater has a reputation beyond reputemaxeater has a reputation beyond reputemaxeater has a reputation beyond reputemaxeater has a reputation beyond reputemaxeater has a reputation beyond reputemaxeater has a reputation beyond reputemaxeater has a reputation beyond repute
Default open trailer with turbo
when hauling on open trailer does the turbo intake need to be covered bagged to keep wind out of the turbo
Rate this post: Yes | No
  #2
Old 12-08-2016, 01:24 PM
Octanee Octanee is offline
Currently: Not set.
Octanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond repute
Default
Quote:
Originally Posted by maxeater View Post
new to turbos when hauling on open trailer does the turbo intake need to be covered bagged to keep wind out of the turbo
Most definitely. I just take 2 or 3 shopping bags and some elastic bands and put it over it, try and suck it down enough that the upper bag doesn't flap a ton, it'll get a hole in it quick. But in either case you don't want dirt getting on it, it's meant to filter snow, not dirt particles.
  #3
Old 12-08-2016, 03:49 PM
Cat800 Cat800 is offline
Currently: Not set.
Basic Member
Cat800 has a reputation beyond reputeCat800 has a reputation beyond reputeCat800 has a reputation beyond reputeCat800 has a reputation beyond reputeCat800 has a reputation beyond reputeCat800 has a reputation beyond reputeCat800 has a reputation beyond reputeCat800 has a reputation beyond reputeCat800 has a reputation beyond reputeCat800 has a reputation beyond reputeCat800 has a reputation beyond repute
Default
Go to Menards-Lowes-Home Depot and get a rubber cap from the plumbing section and get a hose clamp. Remove air intake filter-install rubber cap with a hose clamp.....
  #4
Old 12-08-2016, 05:33 PM
Currently: Not set.
Default
thanks easy fix
  #5
Old 12-08-2016, 10:29 PM
Givemeaboost's Avatar
Givemeaboost Givemeaboost is offline
Currently: Not set.
Givemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond repute
Default
You don't want the wind to start spinning your turbine with out the engine running to lubricate the bearings. keep it covered when transporting it.
Ken...........
__________________
03 rx1 mtn with homebuilt turbo , 159 finger track , Rev tank and seat. 01 Mountain Max
  #6
Old 12-08-2016, 10:44 PM
Currently: Not set.
Default
Ken...........
__________________
  #7
Old 01-30-2017, 07:11 PM
snobeel snobeel is offline
Currently: Not set.
snobeel has a reputation beyond reputesnobeel has a reputation beyond reputesnobeel has a reputation beyond reputesnobeel has a reputation beyond reputesnobeel has a reputation beyond reputesnobeel has a reputation beyond reputesnobeel has a reputation beyond reputesnobeel has a reputation beyond reputesnobeel has a reputation beyond reputesnobeel has a reputation beyond reputesnobeel has a reputation beyond repute
Default
I use a $10 goretex stuff sack from one of my local mountaineering shops. Seems to work great and it is an easy on/off with a draw string. They come in multiple sizes.
  #8
Old 01-30-2017, 08:13 PM
Jago Jago is offline
Currently: Not set.
Jago has a reputation beyond reputeJago has a reputation beyond reputeJago has a reputation beyond reputeJago has a reputation beyond reputeJago has a reputation beyond reputeJago has a reputation beyond reputeJago has a reputation beyond reputeJago has a reputation beyond reputeJago has a reputation beyond reputeJago has a reputation beyond reputeJago has a reputation beyond repute
Default turbo intake cover
Will a sled cover put over the entire sled also work?
  #9
Old 01-30-2017, 11:01 PM
Currently: Not set.
Default
small plastic bag with a cord clip works great
  #10
Old 01-31-2017, 09:05 AM
TheBreeze's Avatar
TheBreeze TheBreeze is offline
Currently: 850 down!
TheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond reputeTheBreeze has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — open trailer heading to WI Thread Starter — dobie Forum — Colorado Replies — 0 Last Post — 03-31-2011 08:26 AM
Thread — 4 Place Open Trailer Thread Starter — hornson3 Forum — Trailer/Transport (Swapmeet) Replies — 16 Last Post — 12-12-2009 06:52 PM
Thread — Wide Open Throttle??? How long can you hold her open in your 2 stroke turbo or BB?? Thread Starter — snowmanx Forum — General Snowmobiling Replies — 24 Last Post — 01-21-2008 02:27 PM
no new posts
