E
This is a thread to discuss positive upgrades please do not flame mtx failures and customer service issues.
That being said this is my latest mtx project I've been spring riding a bunch the last month a and got it working as good or better than my super mod timersleds I've built.
This one is the original scout model which is basically the same as the new ones but has a steel backbone and a disc brake on the jackshaft. the only complaint I have so far is the overzealous tilting but is really no worse than camso and once I got used to it I really like it. It will wash out easier on side hills but so does the camso just pick lines accordingly and have a blast.
This one like all the dedicated bikes in my fleet has had the backbone shortened to move the track 4 inches closer to the rider. You can see I moved as much weight as I could to the back as well. after doing this I still felt like it had a little more weight on the front end than I am used to especially compared to my timbersled sx two stroke.
to get the front end lighter I tied 10 wraps of climbers rope to couple the rear slider to carry more weight on the front of the rails. This is working really well. I tried 4 wraps before but it stretched the rope beyond its limit and lost tension. climber's rope is stretchy like a bungee and 10 wraps creates a lot of force but still will Flex when needed to.Some guys have put a spring on the front of the slide coupler but I'm not sure the spring was stiff enough to carry any weight. As you can see the rope is carrying all the weight without a rider. It rides more neutral than my ts. I can still lift the front when I need to but it doesn't lift under throttle unless I want it to. the timber sleds I've built with light front ends always lift under throttle because of the force of the center shock and location of the swing arm.time will tell how it will work in pow. I will probably put a spring rear bushing to dampen any rearward rocking at some point when I can test it in deep snow next fall.
