Upgrade to Premium
Yamaha: Boosted Sleds (Turbo or Supercharged) Turbo discussion for Yamaha aftermarket Turbo or Super Charged sleds.
Reply
  #1
Old 03-23-2016, 03:10 AM
Sunvang Sunvang is offline
Currently: Not set.
Sunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond repute
Default McXpress turbo boost leak?
2016 Viper MTX with McXpress 270hp kit.
Im loosing boost pressure, gone from 15psi and down to about 10psi. Checked the clamps ans silicone hoses between the IC and throttle bodies and it looks fine, cant see any signs of leaking from the hose into the IC either.
Changed the silicon hoses to new longer ones, and new and better clamps. Secured the intercooler to the frame with clamps.
Worked well and charged 15psi for about 150km then i started to loose pressure again. Goes down to 10psi again.
Any tips where to look next? Or any other ways to check if the leak is from between IC and throttle bodies?
Rate this post: Yes | No
  #2
Old 03-24-2016, 09:05 PM
up-high's Avatar
up-high up-high is offline
Currently: New femur and a new knee and more metal in hip!!
up-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond reputeup-high has a reputation beyond repute
Default
If you have access to air, get a piece of abs pipe the same diameter as your air intake hose(where air filter is) and a cap. Install air valve in cap(I just heated the air valve and screwed it into the abs) and then clamp to air intake hose. Regulate air pressure to 15 lbs and then charge system. Listen for leaks and spray soapy water on all connections and look for bubbles. Check charge tube, bellows, etc.
__________________
65/121 It don't get any lighter!
BERRGG
It's Mountainhorse time now!!!
  #3
Old 03-25-2016, 08:20 AM
thamax thamax is online now
Currently: Not set.
Basic Member
thamax has a reputation beyond reputethamax has a reputation beyond reputethamax has a reputation beyond reputethamax has a reputation beyond reputethamax has a reputation beyond reputethamax has a reputation beyond reputethamax has a reputation beyond reputethamax has a reputation beyond reputethamax has a reputation beyond reputethamax has a reputation beyond reputethamax has a reputation beyond repute
Default
check your exhaust header for cracks by the welds and flex joint. throttle bodies to motor could be leaking just inspect to see if they popped off or not. bov valve and wastegate should be checked to
  #4
Old 03-25-2016, 10:10 PM
up-high's Avatar
Default
Sounds like cracks in exhaust bellows. Runs fine until heat builds up and cracks expand.
__________________
BERRGG
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Boost Leak? Thread Starter — powerstroke 350,700 Forum — Arctic Cat: 1100 ProClimb Replies — 5 Last Post — 01-17-2015 08:59 AM
Thread — Nytro Mcxpress 270 max boost? Thread Starter — DylanBoost Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 5 Last Post — 10-21-2014 04:30 PM
Thread — boost leak Thread Starter — tylerearl88 Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 9 Last Post — 12-23-2010 02:02 AM
Thread — MCXpress Boost adjust Thread Starter — Snoboner Forum — Yamaha Replies — 21 Last Post — 05-11-2009 12:25 PM
Thread — McXpress Rx-1 - Max boost question Thread Starter — Martinmod Forum — Yamaha Replies — 7 Last Post — 12-30-2007 06:44 PM
no new posts
