I prefer the free float.
Make sure your track tension is correct and aligned (maybe even a little loose). Then take out all the secondary shims. Spin the track (off the ground). Measure from the stationary sheave to the bulkhead with a precise ruler. Then push the secondary in flush and measure again. The difference will be the amount of shim spacing you will need to put in.
Then do the deflection. Spin the track and then let go of throttle, it should not come to a complete stop, it should just barely creep along (you want the belt as tight as it can be without the sled driving away from you when you get off of it). Once you have this pretty close, do another free float.
Do this and your sled will run like a champ and your belts will last forever.
