Would it be better to remove the track or take motor out to replace it?
Note: this_feature_currently_may_not_be_available_in_some_browsers
Thanks for the info .You will have to take the track out and pull the drive shaft to drill the rivets out and replace them ( I'm assuming the rivets come in from the track side? Even if the upper row of rivets is installed from the top, you will still need the track and drive shaft out to clear the hose barbs). You should have enough room to remove the hose clamps and the hoses with the engine in place. FWIW
P.S. I do have a brand new one here, part #2511304, I'd make you an excellent deal on; if you have not already sourced one.
