no overheating here!
T
tbeaton
558
90
MA
finally was able to get out this past saturday and put a few miles on the pro. i did a few things over the past month to help eliminate the over heating issue with these sleds. we had maybe 8 inches of snow and def less on the trails where i rode and it was almost 40 deg outside. with all this talk about snow flaps i decided to try the pdp long flap. with my scratchers down, the pdp flap and the stock coolant changed out for engine ice i never saw temps over 130, with it running around 125 most of the time. i was quite happy with that as i was a bit worried that i was going to have major issues running this sled in new england. on another note, didn't realize how much coolant there is in these sleds, took over a gallon to fill it, probably close to 1.5 gallons before the resi was full.
T
tomlee76
New member
Nov 30, 2007
102
4
18
51
Bedford NH
I was in the same spot with my SB Assault with a 2" track. Didn't run the scratchers and never saw over 126 and I was not that kind to the little lever on the right. I was surprised how good it actually can be with 8" of snow. Sad state of affairs snow wise out here this year though. It will come, or at least it better.
Boston Racing
1,628
Colorado Springs, CO
I don't think you have enough miles in different conditions to declare that anything you did helped, other than to make you feel better and stimulate the economy. My stock pro flap, Stock coolant keeps mine at 125 as well with the scratchers down. Mine was on a packed trail without the 8 inches of fresh you rode in. It was also a 40* day. I have 260 miles on mine so far this season and mine has a turbo heating up the coolant as well!
Scratchers are the key, without them I was seeing 160-170.
M
Nov 28, 2007
735
526
93
58
or
wait until theres no fluff and your riding setup for mile after mile. the little things help but if you ride a lot of hardpack a real cooler is gonna be the only answer to "cure" the problem. especially if your ride in spots where you're constantley going 5-10mph and your not able to open it up. not saying its impossible to do but we spend quite a bit of time in the spring with the panels open and stacking tons of hardpack on the tunnels... i did put engine ice in my buddies at the begining of the season and am waiting until it gets set-up to see how much it helps. the rides we've done together so far have had enough fluff that they both ran the same temps.
T
tbeaton
558
90
MA
far from fresh snow, it has rain'd, froze, snow, rain'd and so on. snow out here in the northeast is far different than out west. turns to rock every night and doesn't thaw out until late every afternoon. i have run sleds in better conditions with worse results. scratchers def helped but when i ran without them i only saw about 135-137. i ran it up and down the mile driveway that was mostly ice and dirt with the same results. the real test would have been on the lake that was all ice and no snow, but i did not bother heading over there. while i agree that i didn't get to ride it that far, it was still far enough in low snow conditions to cause it to over heat.
T
tbeaton
558
90
MA
wait until theres no fluff and your riding setup. the little things help but if you ride a lot of hardpack a real cooler is gonna be the only answer to "cure" the problem. especially if your ride in spots where you're constantley going 5-10mph and your not able to open it up. not saying its impossible to do but we spend quite a bit of time in the spring with the panels open and stacking tons of hardpack on the tunnels...
there is zero fluff out here at this time. we have had just about the worst start to a season you could ever imagine. largest storms this year were around halloween and thanksgiving and those melted days after they fell. the scratchers were throwning up some nice hard chunks. the 40 deg weather helped to loosen it up a bit, but then it was dirt.
A
Jan 30, 2011
313
104
Palmer AK
Not to bag on any products (Engine Ice or or propylene glycol) but most of these miracle products are like the magnetic fuel line device. Adding a flap, cooler or running with the scratchers down is the real solution. That is why they sell them with scratchers stock, they have taken every extra bit of weight off but added these, they know the heat is an issue. If you think these other product or additives will work then it will be difficult to dissuade you but in reality the gains are minimal at best.
I posted on a similar thread in DOO talk (I run a super wide and haul freight with it) about this same topic (Evans waterless coolant), I did a little research, here is what I found.
I am not a fluid specialist, but have taught General Chem at the high school and college level for 15 years so I have a fair grasp on the physical characteristics of liquids. As I typed this it becomes a bit of a lecture on Chemical properties but I wanted help you understand my thinking and make a informed decision. I include the links I used if you wish to see what I based my points on.
At first I saw no reason it would not work, I would guess it was a large molecule fluid, oil, Ammonia or the like with with a higher Boiling Point and greater ability to remove heat. The question is how much better is it? The answer is most likely it is not. I am also skeptical because some of the science stated in the "How it works" is very weak IMO and appears to be selling points bolstered by big words that seem to make perfectly good sense at the first glance.
My thinking was that the creation of hot spots are normal, If you have ever burned a hole in a piston you have seen it first hand. To imply these hot spots create a detonation or a cook off is a stretch. The piston will get hot, the cylinders will get hot and so will the head. A larger radiator or different thermostat can help this. So a fluid that removes heat better than water is needed. The flow of the coolant is mixing like a stream, there are hot and cooler spots within the fluid. The important point is that the specific heat of water is 4.184 and aluminum .897, that means that water can carry 4.66 times more heat per unit of mass than aluminum. I left the units out of it on purpose.
I looked for some high heat capacity fluids and found that water was the highest I found.
http://www.engineeri...uids-d_151.html
I looked for all substances, Hydrogen gas is great but a bit explosive under heat and pressure.
http://en.wikipedia....heat_capacities
I was wondering what is this amazing stuff!
I looked at the toxicology to see what this stuff really was:
Evans coolants contain proprietary blends of glycols, including ethylene glycol. Which is in your antifreeze & has a lower heat capacity than water and you enhance the boiling/ freezing point by mixing it with water. They also state "The new coolant, EVANS Non-Aqueous Propylene Glycol (NPG)"... This is used to Deice aircraft and RV antifreeze. I included a MSDS sheet for RV antifreeze.
http://www.shamrockc...SPrestRVAf.html
http://www.engineeri...ycol-d_363.html
So now I am thinking this stuff is what I already have. As for the micro bubbles and hot spots it all sounds good if you buy their product.
IMO this stuff was presented with some amazing data, better fuel economy, safe for the environment, less reactive and better for your car. All to get you to spend $40.00+/- per gallon for a ethalene/ propylene glycol mix that will not work as well as a $12 jug of Prestone and water at 60/40 from your tap."
skibreeze
10,463
3,477
Colorado Springs
This weekend I found out by accident a small thing that made a big difference. I was having issues on the trail to our riding area, temps were hitting 150-170. I found that the scratchers were only an inch or so from the track. I bent them so they were further away and the temps went back down below 140. I think that the spray wasn't able to get above the track when they were super close.
T
tbeaton
558
90
MA
most of the time i don't buy into the hype of the additives and things like that. i had thought about engine ice back in 10 when i had my 600rs, but i decided not to run it. on days like this past weekend i had alot of issues with it over heating. many guys on dootalk said they were running it with great success, but again i never tried it. now i hear about the pros over heating easily so i figured that it couldn't hurt to try the stuff, after all alot of people said it worked. now i could have run the regular coolant but my sled is stored 4 hours away from my house and i wanted to get everything done to my sled before i brought it up there this weekend. will i ever know if it really works or not? probably not, but my sled stay'd at a good temp all day, even slowing down for short periods of time and with scratchers up. do i swear by the stuff? no, not at all, just telling people what i did to help the known issue. i was more excited that i actually got to ride the sled than anything else. i will be back up in 2 weeks to ride again if we get any more snow, what was there is no longer and now its pretty much ice.
T
tbeaton
558
90
MA
what are your trails like out there? your snow typically has less water content than ours, do the trails pack down alot? there were times last year that we couldn't break thru 3-4 of snow off the trail as it became so hard. tends to be typical for the northeast.
skibreeze
10,463
3,477
Colorado Springs
It was like concrete, but not ice.
Reg2view
2,392
1,600
PDP long flap made a real difference in very marginal snow conditions for a 2011 pro over last year. Speed at 20, +-5. Better, and managable, so far. If you have to run poor snow.
J
Jaynelson
5,542
Nelson BC
Lots of the heat issues are people refusing to run scratchers for reasons that continue to boggle my mind.
