I recently installed a bung into the fuel injection rail on my Nytro in effort to make it a returning system like the apex. I took the sled out today and now my rising rate regulator no longer increases fuel pressure as the boost comes on. To troubleshoot I pulled off the sensing line from the charge tube regulator and connected it to a regulated shop air supply. By adjusting the regulator I could then manipulate the injection pressure as you would expect. I also noticed the AFR would drop from 13:1 to 11.5:1 as I increased the pressure at idle.. Sounds good right?? Well hooked it back up to the charge tube and took it for a spin to find the same issue fuel pressure stuck at 40psi regardless of boost pressure.. Now I'm wondering if my plumbing is correct..
Plumbing before:
Standard PL stage 3. Fuel tank to fuel pump to TEE fitting supplying both the rising rate regulator and fuel rail. Regulator returns to the tank.
Plumbing now:
Fuel tank to fuel pump to injection rail through rail to regulator and back to the tank.
Regulator is a 2:1 FZ1 Power Valve whatever that is supplied with the PL kit. Did I do something wrong?? The regulator senses from the charge tube, and all my other boxes and guages sense from the intercooler.. Boost was approx 10psi while testing.
Thoughts?? Thanks in advance. Seanny
Plumbing before:
Plumbing now:
