Upgrade to Premium
Polaris: 900 05-06 Polaris RMK 900
Reply
  #1
Old 12-13-2009, 03:33 PM
yz400ex yz400ex is offline
Currently: Really?? Whats next??
yz400ex has a reputation beyond reputeyz400ex has a reputation beyond reputeyz400ex has a reputation beyond reputeyz400ex has a reputation beyond reputeyz400ex has a reputation beyond reputeyz400ex has a reputation beyond reputeyz400ex has a reputation beyond reputeyz400ex has a reputation beyond reputeyz400ex has a reputation beyond reputeyz400ex has a reputation beyond reputeyz400ex has a reputation beyond repute
Default fuel tank recall?? How to remove fuel tank?
I am wanting to know a little more about the fuel tank recall.. I noticed today that mine is cracked around the cap area so its leaking a little.. What was the recall for? How do I know if it has or hasnt already been repaired with the replacement tank? If this repair isnt covered and I have to replace the tank myself, How hard is it to remove and what if any special tools do I need?
Rate this post: Yes | No
  #2
Old 12-13-2009, 03:40 PM
ghostwhite ghostwhite is offline
Currently: FINALLY HOME!!!!
ghostwhite has a reputation beyond reputeghostwhite has a reputation beyond reputeghostwhite has a reputation beyond reputeghostwhite has a reputation beyond reputeghostwhite has a reputation beyond reputeghostwhite has a reputation beyond reputeghostwhite has a reputation beyond reputeghostwhite has a reputation beyond reputeghostwhite has a reputation beyond reputeghostwhite has a reputation beyond reputeghostwhite has a reputation beyond repute
Default
I don't know what the recal was for as it was already done when I got mine. I would check with a good dealer nearby and ask them if they will cover it under warranty. (good luck)
It is pretty simple to remove. You will need a fuel line disconnect tool set which you can pick up from Napa or the like for under 15$ Remove the console, remove the rear compartment and unbolt the tank, use the disconnect tools to pop the lines apart and disconnect the wiring connector and it will slide out.
On the way home
  #3
Old 12-13-2009, 04:04 PM
jtpolaris's Avatar
jtpolaris jtpolaris is offline
Currently: Just left cooke
jtpolaris has a reputation beyond reputejtpolaris has a reputation beyond reputejtpolaris has a reputation beyond reputejtpolaris has a reputation beyond reputejtpolaris has a reputation beyond reputejtpolaris has a reputation beyond reputejtpolaris has a reputation beyond reputejtpolaris has a reputation beyond reputejtpolaris has a reputation beyond reputejtpolaris has a reputation beyond reputejtpolaris has a reputation beyond repute
Default
The update was a glue in insert into the neck
__________________
2013 800 Pro Rmk 163-xxxmodrod vents, mds clutching,silber, tki,B&M fab.
The Following User Says Thank You to jtpolaris For This Useful Post:
sleddude (12-13-2009)
  #4
Old 12-13-2009, 04:07 PM
Default
Heres the Tool
On the way home
The Following User Says Thank You to ghostwhite For This Useful Post:
yz400ex (12-13-2009)
  #5
Old 12-13-2009, 04:36 PM
sleddude's Avatar
sleddude sleddude is offline
Currently: Not set.
sleddude has a reputation beyond reputesleddude has a reputation beyond reputesleddude has a reputation beyond reputesleddude has a reputation beyond reputesleddude has a reputation beyond reputesleddude has a reputation beyond reputesleddude has a reputation beyond reputesleddude has a reputation beyond reputesleddude has a reputation beyond reputesleddude has a reputation beyond reputesleddude has a reputation beyond repute
Default
Quote:
That was the first recall. Then Polaris recalled the entire tank. The tanks filler necks were cracking and would let dangerous fumes and gas out.
Here's a link about the recall.
http://www.snowmobile.com/news/polar...azard-533.html
__________________
2009 M1 LE SLP pipe k-Mod 174 X3
2006 900 RMK 166 SLP pipe 2.6 power claw
The Following 2 Users Say Thank You to sleddude For This Useful Post:
94fordguy (12-13-2009), Fast Freddie (12-13-2009)
  #6
Old 12-13-2009, 05:21 PM
Default
so mine is cracked around this filler neck.. Is there anyway I can tell if this was a replacement tank or if it is still covered under the recall warranty?
  #7
Old 12-13-2009, 05:23 PM
Default
Quote:
Originally Posted by ghostwhite View Post
Heres the Tool
How is this tool even used?? Will I need to relieve the pressure in the line prior to disconnecting the lines?
Does anyone know where I can find a diagram of the fuel lines being disconnected and the process for doing so?
  #8
Old 12-13-2009, 06:30 PM
sleddude's Avatar
Currently: Not set.
Default
There's 2 lines that need to be disconnected. The one with the fuel filter attatched right behind the secondary clutch towards the engine and the second is the supply line coming out of the tank. The tool pushes down some tabs that connect the metal fuel lines and you just pull them apart. A little bit of pressure will relieve when you disconnect the lines, most of the pressure is in the fuel rail. You may have to prime the pump to get to pressurize the lines when done.
__________________
  #9
Old 12-13-2009, 06:32 PM
polhiker polhiker is offline
Currently: Not set.
polhiker has a reputation beyond reputepolhiker has a reputation beyond reputepolhiker has a reputation beyond reputepolhiker has a reputation beyond reputepolhiker has a reputation beyond reputepolhiker has a reputation beyond reputepolhiker has a reputation beyond reputepolhiker has a reputation beyond reputepolhiker has a reputation beyond reputepolhiker has a reputation beyond reputepolhiker has a reputation beyond repute
Default
take thew vin # to a dealer and they can tell if it was ever done,and it should be still covered as my dealer just did one for us.
  #10
Old 12-13-2009, 06:40 PM
sleddude's Avatar
Currently: Not set.
94fordguy (12-14-2009), Fast Freddie (12-13-2009)
  #11
Old 12-13-2009, 06:58 PM
Click Here to Register
  #12
Old 12-13-2009, 09:29 PM
speedemon speedemon is offline
Currently: Not set.
Basic Member
speedemon has a reputation beyond reputespeedemon has a reputation beyond reputespeedemon has a reputation beyond reputespeedemon has a reputation beyond reputespeedemon has a reputation beyond reputespeedemon has a reputation beyond reputespeedemon has a reputation beyond reputespeedemon has a reputation beyond reputespeedemon has a reputation beyond reputespeedemon has a reputation beyond reputespeedemon has a reputation beyond repute
Garage
  #13
Old 12-13-2009, 10:05 PM
  #14
Old 12-14-2009, 04:18 PM
94fordguy's Avatar
94fordguy 94fordguy is offline
Currently: Doing yard work.....
94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute
  #15
Old 12-14-2009, 06:46 PM
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
no new posts
