KTM 520 BB Gearing
M
Jan 14, 2004
3,079
1,390
So I've been reading all these gearing threads and it got me to thinking. My bike is an 08 carbed KTM 450 EXCR. I've had this bike for years and its served me well but it needed some love at the end of last season. I just got the motor back from Thumper Racing where I had Travis convert it to a single sump and add a big bore kit making it a 520. I know the first thing everyone asks is why not just buy a 530, well the answer is the 530 uses a different crank than the 450 which actually makes it a stroker where the 520 is a bore so it still revs like a 450. The big advantage of the 520 is it makes about 30 percent more power down low, peak power is just under 60 but its in the meat of the power band where the real benefits are so I won't need to rev the pi$$ out of it anymore. The Exc being street legal has the wide ratio tranny, I have a 12 tooth front but I ran a 13 last season and on long pulls I had to kick it down from 3rd to 2nd most of the time. It would be nice to be able to pull 3rd and hold it, the BB should help that.
So im going to a LT this year from my ST what gearing will work best with my new setup?
M5
F
funjunkie
19
18
48
I would run 13 17 and 16 20. That should allow you to be able to always pull third.
Ryanexcr
167
55
Washington State
530 EXCR 500 EXC gearing
I used to run a 530 EXCR and now I have a 500 EXC so I have been messing with gears on both bikes and I found my favorite is 12-17-20-17
so basically all you do is swap the Timbersled outside chain case gears and it makes it run like the race bikes almost but you actually gain that extra gear up top for the groomed trail riding, And third pulls great now. First used to be so useless and this fixes it for sure.
mnsnowhawk
398
137
Dayton, Minnesota
I am going to be installing my kit on a 500 exc so I'm interested in your setup also. I take it the 16 tooth chaincase sprocket needs to be purchased through timbersled. But if the 12 engine sprocket works, that would be easier. Hopefully more have experience on similar bikes and will chime in. There has to be a good setup to get the wide ratio bikes closer to the short ratio ones with different gearing on the kits.
M
Jan 14, 2004
3,079
1,390
My kit was brand new last season. When I installed it the chain was way too tight to use the 13 so I ran the 12 for one day till the chain stretched. I notice this year there are some marks on the under side of the MH frame where the chain passes by. I'm wondering if it is from the one day I ran the 12. Is the 12 too small a diameter or did I just let it get too far out of adjustment one day.
M5
M
Jan 14, 2004
3,079
1,390
So here are the KTM gear ratios wide ratio and close ratio.
Wide ratio. Gears/teeth 1st to 6th 14:36, 17:32, 19:28, 22:26, 24:23, 26:21
On wheels 14:48 sprockets. Ratio. 19.18, 14.40, 11.64, 9.33, 7.57, 6.38
Close ratio 16:32, 18:30, 20:28, 22:26, 24:24, 21:18
15.80, 13.16, 11.06, 9.33, 7.90, 6.77
It's interesting to see the ratios for 4th are identical and 5 and 6 are close but who really cares. Clearly the biggest difference is first gear, it's really short on the wide ratio 2nd and 3rd aren't really that different.
M5
Ryanexcr
167
55
Washington State
I tried the 16 on the inner jack shaft and it was better but I was not happy still and finally changed it back to the 17 on the inner jack shaft and it is kind of a pain to swap that one out for sure. :doh:
For the 500 EXC the best setup after about 6 tries is the 12-17-20-17
and this is an easy one to do takes 5 min.
Ok I am done with this since I have detailed info about this in a previous thread. :lalala:
