600 rmk water pump
snowman70
New member
Mar 4, 2008
70
53
I have an 06 600 rmk that I need to check the water pump on. Where is it located and how do you access it?
MARV1
8,980
1,593
Kotlik, AK
Under your y-pipe. Might have to lift the engine to get to all the bolts. Why do you need to check it? Never had one give out on me, flow problems are usually the thermostat.
snowman70
New member
Mar 4, 2008
70
53
I've removed the thermostat. Temp light comes on after about 5 minutes of operation. Left footrail is hot, rear heat exchanger is lukewarm and right rootrail is ice cold. I'm open to any ideas because getting to that water pump looks like a real pain.
MARV1
8,980
1,593
Kotlik, AK
Take off the right hose from the rear to the right exchanger, most likely blocked or have ice formation.
