Thanks guys...plugs actually look pretty good, Afr ratio is ok when running decent, EGT are decent, actually getting hotter egts on rich side...assuming raw fuel in Y pipe???....more concern about the stagger...sent off injectors to be flow rated and cleaned just to make sure not having an injector problem...might have to look into programming to even things up a bit. Thanks again for looking.
