yeah speed, without oiling the rings I would imagine you would see that much on a fresh engine...and I suppose if you did check on a fresh rebuild and periodically there after it would give a fair idea on the condition of the rings...we mainly used a leakdown to check valve to seat seal on our big block chevy race motors that we were zinging the rpms on..running very small stemmed titanium valves(11/32" stems on a 2.4" intake, 2.00" exhaust valves) on a big roller cam(.822" intake and .865" exhaust lift) we were on the constant look out for signs of light valve float(valves tapping a piston dome), stuff that you could miss on a compression test would show on a leakdown...it was a constant battle keeping the valvetrains in running so much rpm..
