Sled is a 2007 mxz xrs 800. First motor blew mag side piston deto, new crate engine with new carb boots blew mag side piston after 1 season. There is a split in the y pipe could this be causing this condition?
well its totally washed so unless there's been a major water leak in that cylinder its running massively rich on at least that side. what does the other piston look like? does it look like its been burning right. is it carbed or efi?
you actually melted the piston...
the cracked ypipe will ADD un metered air (lean out)...add possible tight squish (I run the 8 hole gasket in ALL 800HO ptek) and possible low octane pump fuel...bingo
top of piston is just aluminum from the melted side...
rebuild...add 8 hole...add .010" shim to needle...drop mains to 430..weld y pipe...put in fresh gas...ride...BJ
