R
I'm in the process of installing the timbersled barkbuster front end and fox float 2's on mine and my brothers 2010 Dragons. I have a couple questions hopefully someone can help me out with.
1. How much air pressure would be a good starting point for the front shocks. The factory swaybar will still be used.
2. When adjusting the caster, I'm putting a level on each ski like it states in the instructions then adjusting the upper ball joint. To get the skis level, the RH ball joint is only screwed out a few turns and showing about 1/8" of threads while the LH balljoint is screwed out quite a few turns and is showing 3/4" of threads. Does this sound right? I would think they would be closer the same.
3. Any other tricks or tips for setting caster and ski alignment?
Thanks in advance for any help or suggestions.
