2007 Turbo Apex 174 Idaho
Jayjaycat
123
Filer ID.
2007 Yamaha Apex SE with 174" track. Sled is located near Twin falls Idaho
$7000.00 obo. It has a boon docker 2860 turbo and inter cooler with Boon Dockers ADA programmed fuel control box, a manual boost controller that's good from 12.5 lbs. to 24 lbs. bast on how the wast gate set up. It has a Boss high rise seat with shovel pouch and storage a K-mod rear suspension set up for turbo Yamaha with Ice Age 174 rail and ice scratchers. There are Avid 7 tooth drivers and a O 2 sensor and shock wave helex in secondary and power quest weighs in primary clutch. Only motor work that has been done is Boon Docker installed a head shim. Sled run on strate 110 and is good for 18 lbs of boost at 8000 feet and up. There are 1995 miles on the sled I purchase it from Boon Docker in March of 2008 and it had a 180 miles on it then which it was just a
stock Apex with there turbo on it open to trades Upgrading to a newer sled. Can email or text pics.Any questions call or text 208-421-1490
Thanks Jason
Jayjaycat
123
Filer ID.
Will be heading to Island Park Idaho with this sled if any one won't to test ride or pick up from there 12-26-13 / 1-3-14
Thanks Jason 208-421-1490
