correct me if im wrong but doesnt the power commander put in its own map? why would you need to remap if you have the fuel controller.
i have the 2010 update and think its crap, i ran very well all last year. so i ordered the power commander 5 to try and fix things.
am i ok with just the fuel controller or do i need a different map as well?
I am in the same boat. Mine ran better last year (until the chaincase started failing) and now after the update the sled runs like poop. Pulling minimal rpms and now I am scratching my head with all sorts of clutching solutions. Maybe that is not the problem. I have the SLP single pipe, air intake, and SLP clutching from 8-10,000 feet. I just got off the phone with a friend and he said Action Motor Sports has had some sleds in already that are having det problems with the new map. I don't want to have to buy a power commander now to fix the "fix". Can you reflash back to 09? Will that void their warranty? So confused.
I ran the same map and have pretty much the same sled. I ran it at 2000 ft but I zeroed the upper rpm numbers for 80-100% throttle just to be safe. Ran great no issues and no bog at all. Clutching is stock springs 10-68, 64/44 helix pulling 8300. I should probably be running 10-70's. I ran with an assult with the udates and mods but no controller, The top end power was the same but my midrange and drivability was way better. His backfired at least 10 times that day.
It is crazy how much fuel SLP is adding in the mid range. some places it is up to 30%. That really explains why so many people have a bog or hesitation or are even scuffing pistons.
For as much as we spend on these things, including mods, transportation, fuel, down time, etc. If I can purchase something that is under $500.00 and adds performance as well as reliability, that's a bargain!!!!
with what we spent on these sleds Iam amazed that people will buy gas racks and BLING .shocks vents and then bit@@h that their sled burnt down or scuffed pistons ,,,but wont spend 300-500$ on a fuel controller ,Mine has had a turbo from day one with a Purelogic controller and the sled has not had one engine issue!!!!!!we put a purelogic controll on my buds assault and again NO issues!! WAKE the F@@k UP!!!!!!!!
