So I just made a bunch of parts to fit an ST kit on my '01 KX500. For the Strut Rod, I made one with 1" aluminum tube with 1/4" walls and heim joints (5/8 tie rod ends from McMaster-Carr) on both ends:
Here are the basic dimensions for the aluminum rod itself:
And the upper strut rod bushing (need 2, I made them out of stainless):
Lower strut rod bushing (need 2, I made them out of stainless):
For the swingarm bushings, I made 2 of these for the drive side of the motor out of aluminum:
And one of these for the non-drive side of the motor, also out of aluminum. For the gap between the non-drive side of the frame and the timbersled, I used a standard 15mm washer that was sanded down a bit on one side. This setup seemed to get the chain in pretty decent alignment on mine.
