07 600 rmk turbo battery/capacitor question
T
TravRMK
New member
Feb 1, 2004
237
4
18
49
Pocatello, ID
Currently running sled with no battery, and my electric pump turns on with a hobbs switch. I plan on deleting the hobbs switch, and running only the ecectric pump. The only issue I see, is when the electric pump kicks on now, at night I can see all my lights dim. Don't want to replace a stator. Would a capacitor work good enough, or would a battery be a better route?
brycter
706
West Haven, Utah
www.turboboys.net
take out all the hobbs switch stuff and the old stock fuel pump. run a rectifier and then if you still want a capacitor then add one.
this will clean up the bottom end and make it alot more user friendly.
T
TravRMK
New member
Feb 1, 2004
237
4
18
49
Pocatello, ID
What rectifier? and where do you wire it in at? Certain specs to look for? Could I get one at radio shack? The setup is similar to the highmarc rec kit. If I remove the hobbs switch, and the relay crap with it, does the rectifier go there. I am semi-retarded when it comes to ac voltage. Would be easier for my thick head if it was all dc
