I assumed you burnt a hole in the piston. Bet I was wrong. As long as you didn't the lower end should be OK. You should replace the pistons at around 4,000 miles. It is your choice. It is apart now. I would also use OEM pistons. Have the cylinders honed to break the glaze. I had mine done at Yellowstone H-D. He checked the ring gap for me also.
