CLUTCH SPECS ON THE PRE-PRODUCTION 2019 850 Patriot sleds.
Rick!
335
Correct...
But maybe able to have a machine shop ream the taper larger for you on an 32mm clutch.
Is there a cutaway of the new crank with the "P-85" clutch shaft? I'm curious. There was very little shaft meat between the taper and end of the spider threads before this new crank...
diamonddave
Chilly’s Mentor
5,577
3,890
Wokeville, WA.
This is my concern as well. Sure hope it's not a repeat of the cracked clutches we saw on late Dragon's and early Pro's.
sledhead_24_7
2,482
1,006
Jackson Wy
So for knowledge, what was the 16-18 800 supplied with from the factory with helix and spring?
tdbaugha
1,402
1,335
USA
It'd been beefed up
Rick!
335
It'd been beefed up
As Granny asked in the Wendy's commercial: "Where's the beef?"
The clutch bolt has been the same forever so either the base diameter of the shaft has been increased (remotely possible but hoses up "low gear"), the drive clutch sits further out on the crank to mis-align the crank snout with the step in the shaft (highly unlikely) or they turned up the material props to the next quench and temper step on the medium carbon alloy ladder (most likely)?
sledneck322
125
21
18
ADK's
Does anyone have the 2019 Polaris RMK clutch weight chart with elevation range from the service manual?
